Ormerod 2 With Duet, Hot end wont heat up with Ethernet...
Posted by yappingboy
March 13, 2015 02:54PM
So, here's my issue...
Ethernet works, and I can get to the web-gui no problems, Printing works over USB no problem. I plug in just Ethernet or even USB and Ethernet, nothing... The thermister on the hot end reports back properly, but, it won't heat up, at all. The web interface gives me nothing to go on, and pronterface says "Setting temperature: no tool selected.", but it ONLY says that if ethernet is up.
Any ideas what could cause this?
Re: Ormerod 2 With Duet, Hot end wont heat up with Ethernet...
March 13, 2015 03:56PM
My guess is that the web interface you are using is not compatible with the firmware and config.g file. Which firmware and web interface versions are they?
