Working without SD Card March 30, 2015 05:59AM |
Re: Working without SD Card March 30, 2015 06:24AM |
Re: Working without SD Card March 30, 2015 07:29AM |
Re: Working without SD Card March 30, 2015 08:32AM |
dc42
If you can get the printer working over USB, then in principle you could "print" the config.g file via the USB port before you do anything else. The snag is that you won't be able to use Pronterface as-is, because it expects an "OK" response after each command, but that doesn't happen until the M555 P2 command is read from config.g. Possible solutions include:
- Modify Pronterface so as to connect by sending M555 P2 instead of M105, or to send both;
- Modify the firmware so as to put it in Marlin emulation mode by default;
- Send M555 P2 via Arduino serial monitor first, then disconnect it and connect Pronterface;
- You may be able to access the printer via Ethernet, if the default IP address (192.168.1.14) is compatible with your network. If so, you could send M555 P2 via the web interface or Telnet, and then connect Pronterface.
But if it's just the SD card socket that has failed, then I suggest you first inspect the soldered connections at the back of it.
Re: Working without SD Card March 30, 2015 11:17AM |
