G-Code Console going mad!!!
Posted by appjaws1
April 10, 2015 08:14AM
Hi I am in the process of printing Erik's overhang test winking smiley and have noticed that the Console is constantly giving the same warning
"Warning: Tools can only be driven if their heater temperatures are high!"
I have T0 (active) set at 195C and T1 (standby) at 155C
I am using a 2 nozzle ormerod with 108c-zpl firmware and web control 1.05
any thoughts?
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
Re: G-Code Console going mad!!!
April 10, 2015 08:28AM
Don't spend any time on this.
I think it is finger trouble on my part, When changing the heater numbering from T1/T2 to T0/T1, I missed and entry in the simplify script section so the g-code file was controlling T1 instead of T0.
At least that is what I think is happening but I don't want to stop the print to find out.
Will the log grow too big and cause problems?
I still have just under 2 hrs to go.
Sorry to waste time
Paul
April 10, 2015 09:01AM
No, I don't think anything bad will happen unless your PC is low on memory - in that case try to reload the web interface after a while.
April 18, 2015 07:32AM
I am still getting the console constantly giving the same warning
"Warning: Tools can only be driven if their heater temperatures are high!" -- What does this mean, which tool, which heater?
I have Heater1 T0 (active) -- set at 193C active and 155C standby
T1 (standby) -- set at 194C active and 155C standby
I am using a 2 nozzle ormerod with 108e-zpl firmware and web control 1.06
I thought that I had the settings wrong in simplify3d, but it all looks ok, so I wonder if this is a problem because of a 2 nozzle set up. The error indicates that perhaps a non existent heater is set low!!! but I just can't find any reason why.
Simplify3d is controling T0 and looking at the g-code it seems ok
G90
M83
M140 S65
M116 S65
M104 S196 T0
M116 S196 T0
M104 S196 T1
M116 S196 T1
M106 S0
G10 P0 R155; Set Hot End 1 heater
G10 P1 R155; Set Hot End 2 heater
G1 E7 F3600 ;reverse end retract filament
M116
G1 E-5 F2200
G1 Z0.9 F800
; layer 1, Z = 0.3
M116
T0
; tool H0.3 W0.6
G1 X50.761 Y58.22 F4600
I'll do some more checking, in the mean time does anything indicate what could cause this problem that you can think of?
April 18, 2015 07:47AM
It's possible that this is related to your two-nozzle setup. I'll check this next week. Thanks for your report!
April 20, 2015 09:45AM
Just to let you know
I have just printed an item with the second nozzle in a fault condition ( which I didn't notice at time of print because I was only interested in Heater 1 (T0) for a 1 colour object).
So the error "Warning: Tools can only be driven if their heater temperatures are high!" did not show in the console
Hope that helps
Paul
April 20, 2015 10:20AM
appjaws1
Hope that helps
Paul
That's how the code is written, a fault condition does not give rise to the message. I think it should, so I'll change it in my next release.
Regarding your earlier post, my most recent release says which tool was not driven in the error message.
