Far away from precision May 01, 2015 04:05PM |
; RepRapPro Ormerod ; Standard configuration G Codes M111 S0; Debug off M550 P****; Set the machine's name M551 P****; Set the password M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; Set the MAC address M552 P192.168.***.***; Set the IP address M553 P255.255.255.0; Set netmask M554 P192.168.***.***; Set the gateway M555 P2; Emulate Marlin USB output M563 P0 D0 H1 ; Define tool 1 G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures M92 E420; Set extruder steps/mm G21 ; Work in mm G90 ; Absolute positioning M83 ; Extrusions relative M574 X0 Y2 Z0 S1 ; set endstop configuration (Y endstop only, at high end, active high) M558 P1 ; Turn Z Probe on M305 P0 H14 L-11 ; set ADC correction M305 P1 H14 L-11 ; set ADC correction G31 Z1.8 P600 ; Set Z probe height and threshold M906 X800 Y800 Z800 E800 ; Motor currents (mA) M201 X800 Y800 Z15 E1000; acceleration tweaks for improved finish M203 X15000 Y15000 Z250 E3600; speed tweaks for improved finish M569 P0 S0 ; Reverse the X axis M556 S78 X-0.63 Y1 Z-0.3 M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M208 X214 Y210 ; set axis travel M208 X-15 Y0 S1 ; set axis minimum T 0 ;End of config
Re: Far away from precision May 01, 2015 04:48PM |
Re: Far away from precision May 02, 2015 06:55AM |
Re: Far away from precision May 02, 2015 07:04AM |
Re: Far away from precision May 02, 2015 12:17PM |
Re: Far away from precision May 04, 2015 02:29PM |
Re: Far away from precision May 04, 2015 02:40PM |
