ABS profile for Ormerod 2 May 06, 2015 12:57PM |
Re: ABS profile for Ormerod 2 May 06, 2015 02:39PM |
Europa
Hi Guys,
Could someone please post a Slic3r ABS profile for Ormerod 2 ?
I have tried modifying the PLA profile but I am not really sure what I am doing apart from setting the bed to 85 degrees and the nozzle to 235 degrees.
Many thanks,
Brian
Re: ABS profile for Ormerod 2 May 06, 2015 04:09PM |
Re: ABS profile for Ormerod 2 May 06, 2015 04:19PM |
Europa
I am considering taking the bed wiring to a 12 volt relay instead which would then switch in and out a seperate power supply of say 15 or 20 volts and rated at 5 amps, this would help achieve the higher temperatures , I assume the bed would be ok with that voltage.
Re: ABS profile for Ormerod 2 May 06, 2015 04:23PM |
Re: ABS profile for Ormerod 2 May 07, 2015 07:37AM |
Re: ABS profile for Ormerod 2 May 10, 2015 06:21AM |
Re: ABS profile for Ormerod 2 May 11, 2015 07:16AM |
Re: ABS profile for Ormerod 2 May 11, 2015 07:39AM |
dmould
The Duet has a 5V switchmode regulator on-board, which is used for the Ormerod 1. When RRP changed the design to the Ormerod 2 they needed to get CE approval, and found that the switchmode supply produced too much EM radiation to comply, so they designed a simple linear 5V regulator and put it on a separate board to feed the Duet on the Ormerod 2 design (see here [reprappro.com] ) However if I understand correctly the Duet is still supplied with its onboard switchmode regulator that could be used instead (the choice of internal or external supply is made via jumper settings).
Re: ABS profile for Ormerod 2 May 11, 2015 08:17AM |
dc42
dmould
The new Duet 0.8 boards have a 5V linear regulator on the main board instead of the switching regulator. RepRapPro have received the first of them, but I don't know whether they are shipping them yet or still shipping the revision 0.6 boards.
Re: ABS profile for Ormerod 2 May 11, 2015 08:35AM |
dmould
dc42
What a pity. Very much a retrograde step in my opinion and completely unnecessary. It is perfectly possible to design an onboard switchmode 5V regulator that passes EMI tests (I do so routinely) and that is the solution that should have been adopted IMO. Having a linear regulator means that the max. input voltage must surely be reduced, and in addition the additional heat generated on the Duet board could necessitate extra cooling in the enclosure. That additional heat will be of extra concern if the Duet's 5V is used to power external equipment such as an LCD display.
Dave
Re: ABS profile for Ormerod 2 May 11, 2015 09:18AM |
dc42
It has already been established that the on-board linear regulator on Duet 0.8 cannot provide enough current (~300mA) to supply a TFT display without overheating, so a separate 5V power brick will be required to power a PanelDue.
