Connecting the Z axis assembly to the Y axis assembly May 12, 2015 11:57PM |
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 02:25AM |
xiandhq
Hi,everyone.
I don't really understand that why the Z extrusion will sit between these two marks?...
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 06:38AM |
ormerod168
xiandhq
Hi,everyone.
The Z extrusion is 20mm on the short side so it all ads up to the total length of the Y extrusion, 210mm + 20mm + 120mm = 350mm
[attachment 54591 z-extrusion_pos.JPG]
Erik
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 01:43PM |
xiandhq
Thank you very much for your replying .But why it is 210mm+20mm+120mm=350mm,not 180mm+20mm+150mm=350mm? Is it because of printer's structural design?
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 03:11PM |
ormerod168
Oh now I see what you mean! (I'm a bit slow ;-)), Its designed so to give the nozzle access to the whole bed - notice the tip of the nozzle has a 35mm offset to the edge off of the Z extrusion, so that makes the position of the nozzle 210mm-35mm=175mm - exactly in the middle of the Y extrusion
Erik
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 11:31PM |
ormerod168
xiandhq
Erik
Re: Connecting the Z axis assembly to the Y axis assembly May 13, 2015 11:36PM |
dmould
ormerod168
Erik
Quite so. If you position it in the wrong place, the printer will still work fine, but you won't be able to print right to one edge of the bed because the bed will reach the end of its travel before the nozzle gets to that edge. The position is where the nozzle (not the X carriage) is at the half-way mark.
Dave
