OK, so I'm having issues getting a pause to work correctly, I'm using
Firmware Version: 1.04g-dc42 (2015-04-20) Pre-release of 1.04g for RRP IR probe issue fix
Web Interface Version: HTML: 1.06, JS: 1.06
First I found this post [
forums.reprap.org]
zombiepantslol
If you're using RRP's official firmware, I think you need to insert "M25" before the Z axis moves to the last layer. You'll have to edit your G-Code file using Notepad++ or so.
If you use either dc42's or my firmware fork, I suggest you use M226 instead. This is the right code for this purpose, but it's still missing in RRP's official firmware.
When you're done, you can run M24 to continue your print.
So I tried using M226, but when I send M24 (or hit resume in the GUI) the printer tries to run off the X and Y axis (X low and Y high) so I have to turn off the printer.
So I tried using M25, but the printer seems to stop before it should.... and when given M24 (or again the GUI resume) it moves to the print and then pauses again. I think it's executing the pause as soon as it sees it enter the buffer instead of waiting to reach it?
So not sure what's going on.... would apreciate some help. For now I'm just going to have to cut my gcode files in half at the change.
