Spring-loaded extruder PTFE liner fastening August 31, 2015 07:02AM |
Re: Spring-loaded extruder PTFE liner fastening August 31, 2015 07:16AM |
Re: Spring-loaded extruder PTFE liner fastening August 31, 2015 07:38AM |
Re: Spring-loaded extruder PTFE liner fastening August 31, 2015 09:41AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 03:20AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 04:19AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 04:31AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 07:43AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 08:28AM |
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 08:34AM |
MetalBasher
This looks like a useful mod, as several people have said. My problem is that the supplied gear set (Ormerod 2) has a slightly elliptical large gear. I've got it fettled to a state where it feeds ok. The spring loaded version will accomodate the ellipticality but that might make the grip on the filament slacken off.
I haven't yet worked out a way of independently varying gear mesh and filament grip! It would certainly mean moving the idler bearing off the motor. One find day...!
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 08:41AM |
MetalBasher
MetalBasher
Re: Spring-loaded extruder PTFE liner fastening September 01, 2015 02:45PM |
dc42
..btw does anyone know why we use 4mmx2mm PTFE tube for the Bowden, but 3mmx2mm for the inlet?
Re: Spring-loaded extruder PTFE liner fastening September 10, 2015 02:41PM |
Re: Spring-loaded extruder PTFE liner fastening September 10, 2015 05:59PM |
MetalBasher
Thanks, spiff and others for suggestions. Plenty to keep me busy. Still getting symptoms of y-axis backlash with belt adjusted to RRP's spec. Isn't adjusting y belt tension a pita?!
Bob
