Duet 0.6 died (ADC) September 21, 2015 06:37AM |
Re: Duet 0.6 died (ADC) September 21, 2015 07:17AM |
Re: Duet 0.6 died (ADC) September 21, 2015 08:02AM |
dc42
I wonder if your head crash could have caused a short circuit somewhere in the head wiring?
dc42
The usual cause of Duets failing with the MCU overheating is believed to be short circuits between the 12V circuitry and the Z probe or thermistor circuitry. Possible ways this can happen include:
1. The original Ormerod 1 instructions did not make it clear which way round the aluminium heat spreader plate should be fitted. This led to some people fitting it upside down, causing it to contact one of the heated bed terminals and be at +12V. If the proximity sensor crashes into the bed fixing clips, it could cause 12V to be fed into the proximity sensor input.
2. When connecting the hot end heater loom to the Duet 0.6, if you plug it in 1 or 2 positions offset to the right, you will feed +12V into the thermistor input.
3. If you miswire the 6-pin hot end connector, you may feed 12V into the thermistor input.
dc42
1. The 5V switching regulator is faulty when you receive the board, causing it to feed 12V through to the 5V rail. [As Replikeo supplies you with an external 5V regulator, they may not bother to test the switching regulator.]
2. This doesn't immediately cause the Duet to fail, because very little is powered from +5V, and most of the things that are can take +12V.
dc42
3. However, feeding 12V into the 3.3V regulator will cause it to overheat.
4. Eventually, the 3.3V regulator fails in such a way as to put more than 3.3V on the 3.3V rail.
dc42
dc42
dc42
Re: Duet 0.6 died (ADC) September 21, 2015 10:59AM |
Re: Duet 0.6 died (ADC) September 21, 2015 11:04AM |
Re: Duet 0.6 died (ADC) September 21, 2015 12:13PM |
Treito
I disconnected the 12V rail already so the supply only is available from USB so that does not make any sense anymore. But I connected the USB connector as I supplied 12V also. If there had been a connection my PC connector would have blown.
Re: Duet 0.6 died (ADC) September 21, 2015 01:17PM |
Re: Duet 0.6 died (ADC) September 21, 2015 02:01PM |
Treito
...Can there be a problem with the ATX power supply? It is a PC power supply...
Re: Duet 0.6 died (ADC) September 21, 2015 02:16PM |
