1st connection USB COM fail blocking in commissioning datasheet help please October 19, 2015 03:50PM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 19, 2015 04:19PM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 19, 2015 04:55PM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 19, 2015 05:13PM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 19, 2015 05:56PM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 02:21AM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 04:45AM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 06:29AM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 07:05AM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 07:21AM |
Re: 1st connection USB COM fail blocking in commissioning datasheet help please October 20, 2015 07:43AM |
dmould
I don't presently have access to the Duet board or layout to check myself ... as the OP has an early kit, could someone (DC42?) verify from his photos that the resistors on the regulator circuit are the correct way around? (You may recall the first batch of Duets had a pair of resistors populated at 90 degrees to their correct orientation).
Dave
