What kind of glass should I have on the heated bed? January 20, 2016 10:39AM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 01:38PM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 02:18PM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 02:59PM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 03:07PM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 04:53PM |
Re: What kind of glass should I have on the heated bed? January 20, 2016 06:49PM |
Re: What kind of glass should I have on the heated bed? January 21, 2016 07:48AM |
Re: What kind of glass should I have on the heated bed? January 21, 2016 01:27PM |
Re: What kind of glass should I have on the heated bed? January 21, 2016 01:58PM |
Treito
Good point. Ordinary glass is not intended to use in high temperature. If the heat is not spread evenly ordinary glass could break. Borosilicat glass can even spread the heat even.
The fiberglass from Replikeo is crap.
Re: What kind of glass should I have on the heated bed? January 21, 2016 02:12PM |
Re: What kind of glass should I have on the heated bed? January 21, 2016 02:43PM |
Re: What kind of glass should I have on the heated bed? January 21, 2016 03:04PM |
David J
I've used several sheets of ordinary 3mm float glass for the last year - not had one break (yet!). I do take care to ensure that the glass is heated evenly (it sits on an aluminium heatbed)....
Re: What kind of glass should I have on the heated bed? January 21, 2016 03:58PM |
ormerod168
David J
I use 4mm float glass (windows glass) on the heatbed directly without any problems, the aluminium heat spreader is not needed IMHO
Erik
Re: What kind of glass should I have on the heated bed? January 21, 2016 04:25PM |
David J
ormerod168
David J
Erik
No heat spreader - the heated bed itself is aluminium.
Re: What kind of glass should I have on the heated bed? January 21, 2016 04:33PM |
