Duet 0.8.5 - "Z-Probe Problem" January 21, 2016 10:16AM |
M561 G1 Z10 F200 G1 X0 Y100 F2000 G30 P0 Z-100000 G1 X160 Y160 F2000 G30 P1 Z-100000 G1 X160 Y0 F2000 G30 P2 S Z-100000 G1 X0 Y0 F2000 G4 P1500 ; Leave the probe there to give the web interface time to report the plane points G1 Z10 F200
; Configuration file for RepRap Mendel 3 ; RepRapPro Ltd ; ; Copy this file to config.g if you have a Mendel 3 ; If you are updating a config.g that you already have you ; may wish to go through it and this file checking what you ; want to keep from your old file. ; ; For G-code definitions, see [reprap.org] ; M111 S0 ; Debug off M550 xxx ; Machine name (can be anything you like). With DHCP enabled connect to (example) [reprappromendel3] (machine name with no spaces). M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0x14 ; MAC Address ;M552 P0.0.0.0 ; Un-comment for DHCP M552 P192.168.1.21 ; IP address, comment for DHCP M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway, comment for DHCP M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X1400 Y1400 Z1400 E800 ; Set motor currents (mA) M305 P0 R4700 ; Set the heated bed thermistor series resistor to 4K7 M305 P1 R4700 ; Set the hot end thermistor series resistor to 4K7 M305 P2 R4700 M569 P0 S0 ; no Reverse the X motor M569 P2 S0 M569 P3 S1 ; Reverse the extruder motor (T0) M569 P4 S0 ; Reverse the extruder motor (T1) M569 P5 S0 ; Reverse the extruder motor (T2) M92 X161 Y160 Z1280 M574 X2 S1 M574 Y2 S1 M574 Z2 S1 M92 E110 ; Set extruder steps per mm M558 P1 X0 Y0 Z1 H5 F100 ; G31 X3 Y-48 Z3.32 P600 ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup) M556 S75 X0 Y0 Z0 ; Put your axis compensation here M201 X350 Y350 Z20 E500 ; Accelerations (mm/s^2) M203 X8000 Y8000 Z250 E3600 ; Maximum speeds (mm/min) M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute M563 P0 D0 H1 ; Define tool 0 ;G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures M563 P1 D1 H2 ; Define tool 1, uncomment if you have a dual colour upgrade ;G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures, uncomment if you have a dual colour upgrade M563 P2 D2 H3 ; Define tool 2, uncomment if you have a tri colour upgrade ;G10 P2 S-273 R-273 ; Set tool 2 operating and standby temperatures, uncomment if you have a dual colour upgrade M563 P3 D3 H4
Re: Duet 0.8.5 - "Z-Probe Problem" January 21, 2016 02:55PM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 22, 2016 10:46AM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 22, 2016 04:00PM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 23, 2016 03:33AM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 27, 2016 01:05PM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 27, 2016 03:39PM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 27, 2016 03:48PM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 29, 2016 07:36AM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 29, 2016 08:22AM |
Re: Duet 0.8.5 - "Z-Probe Problem" January 30, 2016 06:05AM |
