problems after ormerod two nozzle update February 28, 2016 12:58PM |
Re: problems after ormerod two nozzle update February 29, 2016 11:28AM |
tstone
..The new dual nozzles seem to be much sharper and they just cut through the kapton tape with ease
..So i am really longing for a reliable printer again. So any hints/ideas are appreciated.
Re: problems after ormerod two nozzle update March 07, 2016 06:07PM |
Re: problems after ormerod two nozzle update March 08, 2016 02:15PM |
tstone
..Basically i just used misprinted parts for cleaning the little cooled down nozzle.
The plastic melts a little and then pulls everything on the nozzle away. This works best if you hit the right temperature point while the nozzle cools off.
Also i noticed that the new smaller fan is very unbalanced and causes a lot of vibration. This might also be a reason for the malfunction of the leveling sensor? I guess i will replace the sensor and see what happens.
PS: The lathe is really cool. I am also toying the idea of getting one but they are quite pricey take up space and so i decided against it. Are you using your
lathe often?
Re: problems after ormerod two nozzle update March 08, 2016 04:22PM |
Re: problems after ormerod two nozzle update March 08, 2016 04:27PM |
Re: problems after ormerod two nozzle update March 08, 2016 04:29PM |
Re: problems after ormerod two nozzle update March 09, 2016 01:40AM |
Darathy
Is that yours? xD
Re: problems after ormerod two nozzle update March 09, 2016 06:56AM |
Re: problems after ormerod two nozzle update March 09, 2016 10:50AM |
Re: problems after ormerod two nozzle update March 10, 2016 08:36AM |
