Hot-end signal influence 2nd extruder steps April 11, 2016 11:49AM |
; Configuration file for RepRap Ormerod 2 ; RepRapPro Ltd ; ; Copy this file to config.g if you have an Ormerod 2 ; If you are updating a config.g that you already have you ; may wish to go through it and this file checking what you ; want to keep from your old file. ; ; For G-code definitions, see [reprap.org] ; M111 S0 ; Debug off M550 PMy RepRapPro Ormerod 2 ; Machine name (can be anything you like). With DHCP enabled connect to (example) [reprapproormerod2] (machine name with no spaces). M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;M552 P0.0.0.0 ; Un-comment for DHCP M552 P192.168.1.50 ; IP address, comment for DHCP M553 P255.255.255.0 ; Netmask M554 P192.168.1.1 ; Gateway, comment for DHCP M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute corrdinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E800 ; Set motor currents (mA) M305 P0 T10000 R1000 M305 P1 T100000 R1000 B4267 M305 P2 T100000 R1000 B4267 M569 P0 S0 ; Set X axis direction M92 E615:615 ; Set extruder steps per mm M92 Z800 M558 P2 ; Use a modulated Z probe G31 Z0 P340 ; Set the probe height and threshold (deliberately too high to avoid bed crashes on initial setup) M556 S75 X0 Y0 Z0 ; Put your axis compensation here M201 X500 Y500 Z15 E500 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X200 Y200 Z30 E20 ; Minimum speeds mm/minute M563 P0 D0 H1 ; Define tool 0 G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures M563 P1 D1 H2 ; Define tool 1, uncomment if you have a dual colour upgrade G10 P1 S-273 R-273 ; Set tool 1 operating and standby temperatures, uncomment if you have a dual colour upgrade
Re: Hot-end signal influence 2nd extruder steps April 11, 2016 05:16PM |
Re: Hot-end signal influence 2nd extruder steps April 12, 2016 01:48PM |
