Re: Help me with my doubts on buying a Omerod2 December 19, 2014 07:33AM |
Vizual54
Got the O2 yesterday and started assembling it in the evening. Was oh so careful with the acrylic y-axis endplates since reading about people cracking them when putting the rods in. No worries though got the y and z axis assembled and started on the x axis yesterday.
Though when I was about to get going today I ran the y carriage back and fourth and suddenly heard a crack. Left endplate had shattered!!
Managed to glue it together to at least be able to continue building. At a closer inspection it seems like the hole for the rod in the y-idler-bracket and the acrylic part didn't line up and that probably put too much stress on the acrylic. Actually the y-idler-bracket was a really bad print compared with the other printed parts. Going to contact RRP tomorrow and see if they can send a new part.
Re: Help me with my doubts on buying a Omerod2 December 19, 2014 02:00PM |
Re: Help me with my doubts on buying a Omerod2 December 19, 2014 03:04PM |
Vizual54
I think that acrylic is a pretty bad choice for those parts since they only have one support which means there will be a lot of force on tje two bolts holding it to the printed parts. Maybe plywood or even better aluminium would be much better.
Re: Help me with my doubts on buying a Omerod2 December 20, 2014 05:37AM |
Re: Help me with my doubts on buying a Omerod2 December 20, 2014 06:45AM |
Vizual54
..Maybe I have to go buy a drill press after Christmas
Re: Help me with my doubts on buying a Omerod2 January 02, 2015 07:48PM |
Re: Help me with my doubts on buying a Omerod2 January 03, 2015 03:37AM |
Re: Help me with my doubts on buying a Omerod2 January 03, 2015 05:46AM |
Re: Help me with my doubts on buying a Omerod2 January 03, 2015 05:50AM |
Re: Help me with my doubts on buying a Omerod2 January 03, 2015 08:23AM |
Re: Help me with my doubts on buying a Omerod2 January 03, 2015 10:22AM |
Vizual54
It appears as the mounting bolts for the hot end has digged into the printed part.
Re: Help me with my doubts on buying a Omerod2 January 04, 2015 02:00PM |
Re: Help me with my doubts on buying a Omerod2 January 05, 2015 03:59AM |
Re: Help me with my doubts on buying a Omerod2 January 05, 2015 08:42AM |
Vizual54
Fixed the sag of the nozzle and tried leveling the print bed a little bit better. Though I'm having a hard time getting it level in all corners, hopefully its because of the broken end plate.
Re: Help me with my doubts on buying a Omerod2 January 05, 2015 12:04PM |
dmould
If the two Y ground rods that the plate is holding are not exactly parallel, it will not be possible to get all 4 corners of the bed to the same height because the front of the bed will move up and down relative to the back of the bed as you move the bed from side to side (Y direction).
Dave
