Re: New experimental firmware 1.00h-dc42 February 16, 2015 07:57PM |
Fixed bug with reading file info that was introduced in version 1.00h
Don't return status as Printing if just running a macro file, return Busy instead
Restored Json buffer size back to 2000 bytes so as to return more files on SD card
Limit the amount of moves we buffer depending on how long they take so as to react faster to speed and extrusion rate changes
Return print time left estimates in M105 S2 status response for PanelDue if printing a file
Show stepper motor currents as integers and do some rounding to get more accurate values
Re: New experimental firmware 1.00h-dc42 February 17, 2015 05:02AM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 05:55AM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 07:08AM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 03:50PM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 04:55PM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 05:27PM |
Re: New experimental firmware 1.00h-dc42 February 17, 2015 06:10PM |
dmould
During the print I figured the plastic could do with being a tad hotter (white filament usually does), so I changed the "230" in the widow to "235" and hit "enter". Unfortunately I had not hit the backspace key hard enough (or the browser missed that keystroke) and instead of "235", I had entered "2305". Within seconds I realised that the temperature graph was going ballistic and quickly corrected the figure to the intended 235 and the hotend LED went out as the temperature reached 250 deg - but the residual heat in the cartridge kept the temperature climbing off the top of the graph before it came down again. And kept coming down, and down ... Meanwhile the print was looking fine despite the brief period of overheat. I paused the print before the plastic solidified in the nozzle. The overtemp had apparently triggered a fault condition in the firmware and nothing I could do on the control panel would reactivate the heater, so I had to reset the printer and scrap the print.
So my request is that a temperature set command be ignored if the temperature is out of bounds rather than attempting to reach a temperature that is above the permitted limit and "deliberately" triggering a fault condition.
Dave
Re: New experimental firmware 1.00h-dc42 February 17, 2015 07:55PM |
dc42
I've implemented that for release in my next version. However, if the temperature overshot to more than 300C (the value that triggers a temperature fault), then you almost certainly need to reduce the S parameter in the M305 command for that heater, to scale back the power. I think I recall from another thread that you have increased the supply voltage to 14V. If that is the case, you need to compensate for the extra 36% power you are giving it.
