Printing quality: pursuing perfection November 01, 2014 02:25PM |
Re: Printing quality: pursuing perfection November 01, 2014 06:15PM |
Re: Printing quality: pursuing perfection November 01, 2014 07:51PM |
knife-edge
So why do you say that you can't use auto leveling with mechanical endstops?
Re: Printing quality: pursuing perfection November 01, 2014 08:11PM |
Re: Printing quality: pursuing perfection November 02, 2014 11:09AM |
Re: Printing quality: pursuing perfection November 02, 2014 06:32PM |
Re: Printing quality: pursuing perfection November 02, 2014 07:21PM |
runninfarmer
You must have your extruder finely tuned to compensate for that much compression?
BackEMF
The wobble, is it in your case caused by an off-center ax coupler, or is the rod itself a bit bend? (or a bit of both?)
Re: Printing quality: pursuing perfection November 03, 2014 12:49AM |
Re: Printing quality: pursuing perfection November 03, 2014 03:42AM |
runninfarmer
With a 0.5mm extruded diameter, if you're extruding rate is the same at 0.1mm vs 0.3mm layer height, how would you not have different layer widths with out decreasing extrusion rate? You'd have more compression at same rates for 0.1mm layer height, unless I'm wrong?
Re: Printing quality: pursuing perfection November 03, 2014 04:33AM |
Re: Printing quality: pursuing perfection November 03, 2014 10:16AM |
BackEMF
Re: Printing quality: pursuing perfection November 03, 2014 02:48PM |
regpye
Out of interest sake, which slicing program are you using? To me it looks like you may be using Cura??
If so, can you try using Slic3r and see if that changes anything in the results?
Re: Printing quality: pursuing perfection November 03, 2014 03:07PM |
BackEMF
For now i managed to compensate the coupler wobble by turning the rod so that the two wobbles cancel eachother out a bit (it still wobbles a bit)
I went to 2 hardware stores today only to find rods that are uncapable of rolling on a flat surface. :-) Not bend a lot, but bend enough to leave them on the shelf and look further..
Re: Printing quality: pursuing perfection November 03, 2014 05:49PM |
cristian
BackEMF
At the top, the rod wobbles not more than 2 millimeters, which become 0.1 - 0.2 millimeters in the printed pieces...
What is the diameter of the threaded rod you are looking for? Maybe thicker is straighter?
Re: Printing quality: pursuing perfection November 03, 2014 06:30PM |
regpye
Smooth Z rods thickest you can use.
Threaded Z rod the thinnest you can use.
No retaining bearing at the top end so the threaded rod can move as needed and not force any unwanted movement to the axis.
Use stainless steel thread for better formed thread.
A good bearing system or use bushes that are free and give a good sliding action.
Re: Printing quality: pursuing perfection November 03, 2014 06:53PM |
cristian
regpye
Thanks Reg. Have you ever managed to remove completely the effect of the wobble on the printed pieces in some of your printers? If yes, how?
I would also like to be able to quantify the wobble: I will have a look at cheap microscopes...
Re: Printing quality: pursuing perfection November 03, 2014 09:16PM |
Re: Printing quality: pursuing perfection November 08, 2014 02:37PM |
Re: Printing quality: pursuing perfection November 10, 2014 04:56AM |
Re: Printing quality: pursuing perfection November 10, 2014 05:23AM |
BackEMF
Another way to reduce wobble might be one of these: [www.sdp-si.com]
the flexible connection might do the trick. If ithe prices aren't too extreme.
And what about printing a flexible coupling?
Re: Printing quality: pursuing perfection November 10, 2014 08:11PM |
Re: Printing quality: pursuing perfection November 10, 2014 10:24PM |
Re: Printing quality: pursuing perfection November 11, 2014 04:57AM |
BackEMF
Also, i'm wondering about the hotend PID settings you are using and what type/brand of PLA that you used for the grey cubes.
Re: Printing quality: pursuing perfection November 11, 2014 11:20AM |
Re: Printing quality: pursuing perfection November 13, 2014 05:07AM |
cristian
BackEMF
I tried to print a flexible coupling and I failed: it is difficult for me to conceive a coupling that preserves rotation and z shift, while being tolerant on x and y shifts...
But if you have some good ideas, please share!
Re: Printing quality: pursuing perfection November 13, 2014 11:44AM |
Re: Printing quality: pursuing perfection November 17, 2014 04:56PM |
cristian
the cartridge falls when the Z motor has no power, although slowly enough not to be a very serious issue;
Re: Printing quality: pursuing perfection November 17, 2014 05:08PM |
regpye
I drop a 4mm ball bearing in between the motor shaft and the threaded rod.
Why??? The rods are now touching, but the transmission noise does not happen because the ball is touching on the centre part of each motor shaft and the threaded rod. The transmission noise happens when square ends are touching and react against each other. The ball stops this happening and also takes up the movement in one direction, but still allows the shafts to flex as needed.
Re: Printing quality: pursuing perfection November 19, 2014 08:51AM |
Re: Printing quality: pursuing perfection November 21, 2014 05:38PM |
BackEMF
why not use GT2 belt?
