Not possible to home Z due to the lenght of Stepper Motors? September 07, 2014 01:15PM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 07, 2014 03:42PM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 07, 2014 03:48PM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 07, 2014 10:48PM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 08, 2014 12:27AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 08, 2014 03:14AM |
regpye
There is definitely no need to use 48mm motors.
I am using 40mm motors on all my i3 machines which need more power than a Smartrap, and I am also using 40mm and even 35mm motors on the Smartraps.
48mm motors are simply overkill.
Re: Not possible to home Z due to the lenght of Stepper Motors? September 08, 2014 05:23AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 08, 2014 05:31AM |
smartfriendz
ho ok.
yes, the only solution i see is to level up the bed. you can do that with wood plank , fixed using the holes for glass holders ( 4 holes M3) , then maybe you can fix the glass holders on the plank , then the glass on the plank too. you should be high enough ?
Re: Not possible to home Z due to the lenght of Stepper Motors? September 08, 2014 07:27AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 10, 2014 03:03AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 13, 2014 08:25PM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 13, 2014 11:19PM |
BackEMF
what about turning the x axis upside down?
with the motor on top...
Re: Not possible to home Z due to the lenght of Stepper Motors? September 15, 2014 02:58AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 15, 2014 03:07AM |
Re: Not possible to home Z due to the lenght of Stepper Motors? September 15, 2014 08:38AM |
