Should I print bushings or buy bearings? October 13, 2014 05:51PM |
Re: Should I print bushings or buy bearings? October 13, 2014 06:09PM |
Re: Should I print bushings or buy bearings? October 13, 2014 11:20PM |
Re: Should I print bushings or buy bearings? October 13, 2014 11:32PM |
Re: Should I print bushings or buy bearings? October 13, 2014 11:39PM |
knife-edge
Sorry reg you just caught me a few minutes too late. I just ordered steppers, ramps, and the linear rods and I decided to go with bearings. I ordered 12 lm8uu's and 10lm6uu's so I'm set for a while.
Re: Should I print bushings or buy bearings? October 16, 2014 12:30PM |
Re: Should I print bushings or buy bearings? October 16, 2014 08:59PM |
gaston
fun to see my video here
I don't know if you see in this video that it isn't really a Smartrap it's her daughter
The Gastrap is a mix of Smartrap, Regpye mod and a little bit of my madness It was full printed on the Smartrap (also bushings ) because I have some meters of stainless steel smooth rod in 10 mm and I wanted to try
More pictures of this "thing" here (clic on picture for next )
Re: Should I print bushings or buy bearings? October 17, 2014 01:23AM |
Re: Should I print bushings or buy bearings? October 25, 2014 05:03AM |
Re: Should I print bushings or buy bearings? October 25, 2014 05:47AM |
mikefiatx19
Just a thought, Delrin is sold in long square bars so in theory you could make your bushings long and rectangular. That way you could even drill small holes through the square bar to mount it to the smartrap. Might make mounting a bit more secure than the cable tie option and it would look more streamlined.
Re: Should I print bushings or buy bearings? October 28, 2014 08:18PM |
Re: Should I print bushings or buy bearings? October 28, 2014 09:26PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Should I print bushings or buy bearings? October 28, 2014 11:33PM |
nophead
I believe Ultimaker have to use bushes because linear bearings don't like rotation and Ultimakers use the same shaft for both.
Bearings should not damage rods in months. They last for years of continuous use for me. The rods need to be hardened steel and h6 tolerance though.
The problem with bushings is they need some clearance giving some slop and that only increases as they wear. I have only had them last for days
Linear ball bearings have pre-load, so there is no slop until they wear out. The downside is more friction and noise. If they run out of oil they seize but a few drops of oil on the rods generally fixes them.
Re: Should I print bushings or buy bearings? October 29, 2014 04:18AM |
Re: Should I print bushings or buy bearings? October 29, 2014 04:44AM |
smartfriendz
personnaly i had a very short and quiet bad experience with brushing.. as with the smartrap, X and Y axis rods are in porte a faux.. we need some balls (no joke here to take the forces along the axis.
I understand well it works when you have only sliding forces .. like on I3 x axis .
Re: Should I print bushings or buy bearings? October 29, 2014 09:11AM |
Is there some special oil to use, because I have tried sewing machine oil and loaded the linear bearing before assembly, and I have also tried lithium grease.
The rods were RF hardened 316 stainless steel ground to size.
Re: Should I print bushings or buy bearings? October 29, 2014 12:31PM |
Re: Should I print bushings or buy bearings? October 29, 2014 02:14PM |
The size of bush is important to match the rod exactly, so maybe tubes ready made may not fit well enough.Quote
runninfarmer
Would delrin tubes work? I've found Mcmasterr-Carr carry's them for imperial rod here: [www.mcmaster.com]. Do you put notches in the inner diameter of your bushings such as in IGUS bearings?
Re: Should I print bushings or buy bearings? October 29, 2014 02:28PM |
Re: Should I print bushings or buy bearings? October 31, 2014 06:59AM |
Re: Should I print bushings or buy bearings? October 31, 2014 07:31AM |
Re: Should I print bushings or buy bearings? October 31, 2014 07:53AM |
nophead
Yes they are lower friction, quieter and won't wear the rods, but will they stay tight for any length of time? My experience with Igus plastic bearings is they were great for a few builds but after that the carriage started racking.
Re: Should I print bushings or buy bearings? October 31, 2014 10:09AM |
Re: Should I print bushings or buy bearings? October 31, 2014 01:00PM |
Re: Should I print bushings or buy bearings? October 31, 2014 07:43PM |
knife-edge
Yup I printed a new bearing plate and bearings lined up so terribly. It took two hours worth of filing to fix it.
Re: Should I print bushings or buy bearings? November 17, 2014 06:47AM |
Re: Should I print bushings or buy bearings? November 24, 2014 09:47PM |
