new jhead support in github December 08, 2014 12:40PM |
Re: new jhead support in github December 09, 2014 02:55PM |
Re: new jhead support in github December 10, 2014 04:10AM |
Re: new jhead support in github December 10, 2014 12:23PM |
Re: new jhead support in github December 10, 2014 02:19PM |
Re: new jhead support in github December 13, 2014 10:19PM |
vegasloki
All Repraps are a work in progress.
Here is a mount for a Rework fan shroud. The shroud is in the Rework Github, the source for the mount attached to this post.
There are both an Inventor ipt file and an stl attached. Looking at it it would make more sense to add a mounting point for the fan to the clamp in the dist rather than the bolt on part I have here.
Edit: The limit switch mounts to the two holes perpendicular to the top of the mount. The spacing is for the original Makerbot style switch on a board, it would need a mod to use a plain microswitch.
The Bowden fillting can be tapped into the top of the hot end. Or in the case of an E3D there is a push in fitting.
