Re: Z Issues December 13, 2014 09:55PM |
jbutj
Any Idea why my smartrap stops levelling the bed at about 10mm off the glass bed? The hotend doesn't touch the glass but it still stops. This is the output from pronterface. It might help
Connecting...
start
Printer is now online.
echoowerUp
External Reset
Brown out Reset
Marlin1.0.0
echo: Last Updated: Dec 13 2014 22:01:00 | Author: (smartfriendz, smartrap1.06)
Compiled: Dec 13 2014
echo: Free Memory: 3538 PlannerBufferBytes: 1232
echo:Hardcoded Default Settings Loaded
echoteps per unit:
echo: M92 X80.00 Y80.00 Z400.00 E153.00
echo:Maximum feedrates (mm/s):
echo: M203 X500.00 Y500.00 Z4.00 E25.00
echo:Maximum Acceleration (mm/s2):
echo: M201 X9000 Y9000 Z100 E10000
echo:Acceleration: S=acceleration, T=retract acceleration
echo: M204 S3000.00 T3000.00
echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
echo: M205 S0.00 T0.00 B20000 X15.00 Z0.40 E5.00
echo:Home offset (mm):
echo: M206 X0.00 Y0.00 Z0.00
echoID settings:
echo: M301 P17.77 I0.88 D89.69
echoD init fail
echo:endstops hit: X:0.12
echo:endstops hit: X:0.11
echo:endstops hit: X:0.10
Loaded C:\Users\England Family\Downloads\jhead_fanj.gcode, 53983 lines
4824.16470692 mm of filament used in this print
The print goes:
- from 62.33 mm to 117.67 mm in X and is 55.34 mm wide
- from 57.34 mm to 122.66 mm in Y and is 65.31 mm deep
- from 0.00 mm to 26.15 mm in Z and is 26.15 mm high
Estimated duration: 1:18:34
Print started at: 22:38:03
Bed x: 30.00 y: 160.00 z: -16.00
Bed x: 30.00 y: 20.00 z: -16.00
Bed x: 160.00 y: 20.00 z: -16.00
Disconnected.
Thanks
Re: Z Issues December 14, 2014 04:40PM |
Re: Z Issues December 15, 2014 05:39AM |
Re: Z Issues December 15, 2014 05:41AM |
Re: Z Issues December 15, 2014 11:31AM |
Re: Z Issues December 16, 2014 02:59AM |
Re: Z Issues December 16, 2014 08:44AM |
smartfriendz
Thank you Mandrav, it is clear expnanation.
But your problem could be that is you do only a G29 , the Z is only going down for 15mm max ( it's a software security). That's why we usually make a home Z before.
To try, you need to be around 10 mm above the bed.
Re: Z Issues December 16, 2014 08:49AM |
Re: Z Issues December 16, 2014 09:51AM |
Re: Z Issues December 16, 2014 09:52AM |
Re: Z Issues December 16, 2014 03:11PM |
Re: Z Issues December 16, 2014 03:51PM |
Re: Z Issues December 16, 2014 03:57PM |
