RAMPS power connection for simple 12V 6A a/c adapter December 28, 2014 11:15AM |
Re: RAMPS power connection for simple 12V 6A a/c adapter December 28, 2014 11:31AM |
Re: RAMPS power connection for simple 12V 6A a/c adapter December 28, 2014 12:00PM |
Re: RAMPS power connection for simple 12V 6A a/c adapter January 02, 2015 07:12PM |
Re: RAMPS power connection for simple 12V 6A a/c adapter January 02, 2015 09:33PM |
knife-edge
I run my smartrap off of a 6a computer power supply with no heated bed and have had no issues. I would just connect the 6a.
Re: RAMPS power connection for simple 12V 6A a/c adapter January 03, 2015 12:36AM |
regpye
knife-edge
Me too, but I do have a heated bed, and it is mains powered. I connect a solid state relay to where the heated bed connects on the RAMPS board and it takes almost no power to run that. The heated bed gets hot very quickly and has given no problems on all my machines. The power supply I use is a small LED supply rated at 6 Amps I have built 63 machines now that way.
Sometimes I use a bigger supply, depends on what is available at the time, however the 6A supply works fine.
Re: RAMPS power connection for simple 12V 6A a/c adapter January 03, 2015 04:09AM |
Re: RAMPS power connection for simple 12V 6A a/c adapter January 03, 2015 07:58PM |
knife-edge
regpye
knife-edge
Mine is the laptop style? Is yours the same? Just out of curiosity because mine was also stated as being for LED's but I've never seen LED's that have pulled 6 amps haha.
Re: RAMPS power connection for simple 12V 6A a/c adapter January 03, 2015 08:01PM |
I had the heated beds especially made for me, the thermistors I supplied and they were inserted into the the silicone bed as it was being made. They have been made to fit my aluminium bed plates that measure 225 x 250mm and have an adhesive back that will stick firmly to the aluminium plate.Quote
loidor
regpye
And I'm curious on what bed you're using =)
Re: RAMPS power connection for simple 12V 6A a/c adapter January 03, 2015 08:50PM |
Re: RAMPS power connection for simple 12V 6A a/c adapter January 04, 2015 12:29AM |
Re: RAMPS power connection for simple 12V 6A a/c adapter January 08, 2015 11:35PM |
