rcjoseb
Which version would be best to use on the SmartRap?
Smartfriendz Github: [
github.com]
Marlin Github a.k.a. Erik Zalm: [
github.com]
Version posted by Regpye: [
forums.reprap.org]
or are they all the same?
Thanks,
Jose
All slightly different.
My latest version is setup for easy setting for auto bed levelling, and I am using long reach tactile switches for the probe.
The tactile switch is more reliable than the micro switch, has a much lighter pressure, is smaller and compact. Needs to have the logic in Marlin reversed the same as an opto switch.
I also changed the pin.h so that the heated bed took the position of the second hotend. I did that because I had a faulty RAMPS board, and after using it in that position found it was better for me, so I set them all the same from there on.
regpye.com.au]
"Experience is the mother of all knowledge." --Leonardo da Vinci
