New very precise Z probe January 31, 2015 07:00PM |
Re: New very precise Z probe February 02, 2015 04:04AM |
ldanut
Since I was never satisfied with existing solutions for probing the bed for autoleveling I designed a new mechanism that seems to be very precise and its not affected by bed surface or dirty hot end nozzle. This mechanism is under testing and will be available in near future.
[attachment 48233 IMG_4248.JPG]
[attachment 48234 IMG_4252.JPG]
[www.youtube.com]
[www.youtube.com]
Re: New very precise Z probe February 02, 2015 04:15AM |
Re: New very precise Z probe February 02, 2015 04:46AM |
ldanut
Yes also I will have a Hall sensor version next. I have ordered customized PBC for hall sensor that is only 20x20mm small and will fit perfectly there.
On my delta printers I use PEI as a bed substrate and works great. No more coating and messy stuff. This is a printer for someone that wants to print with blue tape and this is how I tested. The problem before was that the tip of hot end was making a hole into blue take and measured wrong Z offset.
What method do you use on printing on the glass? That white glue thing diluted with water?
Re: New very precise Z probe February 02, 2015 07:11AM |
Re: New very precise Z probe February 02, 2015 07:43AM |
ldanut
I never herd about this but sounds very interesting. I will definetly try it. Thanks. I like the fact that you don't have to reapply before each print.
Re: New very precise Z probe February 02, 2015 07:45AM |
Re: New very precise Z probe February 02, 2015 07:46AM |
Re: New very precise Z probe February 10, 2015 10:41AM |
Re: New very precise Z probe March 06, 2015 03:28PM |
ldanut
Do you use PLA or ABS? For PLA normal glass is ok since its only 60-70degree but for ABS at 110degree the regular glass can crack very easy from temperature variation.
Re: New very precise Z probe March 06, 2015 05:45PM |
congrats. I should try this system. i still have a lot of servos, so its nice to use them
Re: New very precise Z probe March 06, 2015 08:47PM |
smartfriendz
it's very nice job idanut.. the level system..and the restcongrats. I should try this system. i still have a lot of servos, so its nice to use them
Re: New very precise Z probe March 08, 2015 09:23AM |
Re: New very precise Z probe March 08, 2015 12:14PM |
Re: New very precise Z probe March 11, 2015 07:03PM |
Re: New very precise Z probe March 11, 2015 10:02PM |
Re: New very precise Z probe March 11, 2015 11:49PM |
From my experience, the micro switches need to be recalibrated after a while of use, the arm seems to bend a little and throw the accuracy out. I went to using the tactile switch with the long button and so far have had no problems at all.Quote
ldanut
I haven't done but I can do it so we can have a better picture. My tests involved printing a lot and see if I need to recalibrate the Z offset after few prints as it happened before. I didn't have to recalibrate the Z offset at all. Whats the best way to do repeatability tests? Just do few times G29 and see the values from console?
Re: New very precise Z probe April 02, 2015 05:21PM |
Re: New very precise Z probe April 02, 2015 07:36PM |
duranza
Are the files for this mod posted anywhere?
Thanks,
Jonathan
Re: New very precise Z probe April 02, 2015 08:15PM |
The servo arm file for the tactile switch is hereQuote
duranza
Thanks,
Jonathan
Re: New very precise Z probe April 03, 2015 05:36PM |
Re: New very precise Z probe May 31, 2015 02:52AM |
Re: New very precise Z probe May 31, 2015 03:37AM |
Re: New very precise Z probe June 05, 2015 02:54PM |
Re: New very precise Z probe June 05, 2015 03:43PM |
Re: New very precise Z probe June 05, 2015 03:49PM |
Re: New very precise Z probe June 05, 2015 03:52PM |
Re: New very precise Z probe June 05, 2015 05:20PM |
Re: New very precise Z probe June 05, 2015 05:26PM |
Re: New very precise Z probe June 06, 2015 05:28AM |
