Hi and help? Smartrap built but... February 26, 2015 01:05PM |
Re: Hi and help? Smartrap built but... February 26, 2015 01:41PM |
Re: Hi and help? Smartrap built but... February 26, 2015 03:03PM |
Re: Hi and help? Smartrap built but... February 26, 2015 03:05PM |
Re: Hi and help? Smartrap built but... February 26, 2015 06:35PM |
Re: Hi and help? Smartrap built but... February 27, 2015 06:30AM |
Re: Hi and help? Smartrap built but... February 27, 2015 09:49AM |
Re: Hi and help? Smartrap built but... February 27, 2015 02:20PM |
Re: Hi and help? Smartrap built but... February 27, 2015 02:25PM |
Re: Hi and help? Smartrap built but... February 27, 2015 03:03PM |
Re: Hi and help? Smartrap built but... February 27, 2015 05:06PM |
Re: Hi and help? Smartrap built but... February 28, 2015 08:16AM |
Re: Hi and help? Smartrap built but... February 28, 2015 11:14AM |
Re: Hi and help? Smartrap built but... February 28, 2015 01:00PM |
Re: Hi and help? Smartrap built but... March 01, 2015 05:38AM |
Re: Hi and help? Smartrap built but... March 01, 2015 09:43AM |
Re: Hi and help? Smartrap built but... March 01, 2015 03:40PM |
Re: Hi and help? Smartrap built but... March 01, 2015 04:45PM |
Re: Hi and help? Smartrap built but... March 02, 2015 11:12AM |
Re: Hi and help? Smartrap built but... March 02, 2015 12:50PM |
Re: Hi and help? Smartrap built but... March 02, 2015 02:30PM |
Re: Hi and help? Smartrap built but... March 02, 2015 03:16PM |
Re: Hi and help? Smartrap built but... March 02, 2015 04:00PM |
Re: Hi and help? Smartrap built but... March 02, 2015 05:33PM |
Re: Hi and help? Smartrap built but... March 04, 2015 04:09PM |
Wibbles
Hi Dan
I only mentioned it as my guess was that anyone who was used to RC kit would do what I was about to do and go buy a servo extension lead to run down to the box and just plug it in.
Ok, I now have this whole thing up and running, just had to make a few adjustments to the print speed (50-60), filament feed and speed, and the nozzle temp (190). I printed one of the parts from the files that you have put in the servo Z section, or tried to? lol. Edges were good, but as height increased the nozzle got closer to the previous layer.
After a couple of false starts I used the sugar /water method to make the first layer stick, and even though I used it directly on the glass, what was printed came off with minimal pressure. Cleaning up a glass bed is a piece of cake with acetone, or if anyone has some lying about, airbrush cleaner.
I now have one problem. I installed the firmware mentioned on the Servo update page, but when I start a print I don't get the auto bed levelling. Is there a trick to activate this, as I think that this was what caused my print to start going awry after a few slices had been printed. Eg - The print head started to smudge at one end of the printed item.
I am guessing that the length of the rod is quite critical to the bed detection. Eg Bed detection without the hot end touching the bed? Does the first layer nozzle height need to be set somewhere?
I am running it from a Windows PC, using Pronterface, and do not have an SD card installed, so if this makes a difference let me know.
Sorry for posting the questions here, but I guess that if anyone else has the same questions at least they will see the answers and know what the solution is.
Regards
Rob
Re: Hi and help? Smartrap built but... March 04, 2015 04:36PM |
