My SmartRap Core Build April 11, 2015 12:35PM |
Re: My SmartRap Core Build April 11, 2015 03:15PM |
Re: My SmartRap Core Build April 12, 2015 10:02PM |
Re: My SmartRap Core Build April 13, 2015 09:51AM |
djinn5150
1. Yes there are some videos see this link Smartfriendz Youtube Channel
2. Yes they need to be mirrored. Your really want to generate a build plate on the youmagine link and break those parts out, if you just view individual parts and try to download the stl you wont get all the parts right. I used cura to just save each axis parts as seperate stl "plates"
3. Yes they are to act as clamps, belts should slide in from top and be held solid.
4. I believe the default head mount will fit an e3d but can't be positive as I never printed it
5. Lube you will want to use a grease, lube the bearings before installing on the rail, personally I use engine assembly lube.
6. Depending on what your after I can help you out with with printing,...I am sure others here as well, but I am having some technical difficulties ATM with my SmartCore so it will be hit or miss for me.
Re: My SmartRap Core Build April 13, 2015 10:08AM |
Re: My SmartRap Core Build April 13, 2015 02:12PM |
Re: My SmartRap Core Build April 13, 2015 05:50PM |
Re: My SmartRap Core Build April 13, 2015 11:41PM |
Re: My SmartRap Core Build April 14, 2015 12:23AM |
Re: My SmartRap Core Build April 14, 2015 01:00AM |
Re: My SmartRap Core Build April 14, 2015 01:19AM |
Re: My SmartRap Core Build April 14, 2015 01:27AM |
Re: My SmartRap Core Build April 14, 2015 02:08PM |
I guess I'm still confused. Because I have the LM8UU bearings I just am having a hard time printing the "head" pieces with the belt clampsQuote
djinn5150
Bushings would go in place of the lm8uu bearings, what cad are you using?
Yeah I'm beginning to realize this actually might be a good idea...Quote
madmike8
Lol, I have so much makerslide and spindle carriages hehe... I could do that...
Re: My SmartRap Core Build April 14, 2015 03:10PM |
Re: My SmartRap Core Build April 14, 2015 04:05PM |
phinsil6
madmike8
What do you think the drawbacks would be?
Re: My SmartRap Core Build April 14, 2015 10:27PM |
Re: My SmartRap Core Build April 16, 2015 02:57PM |
Re: My SmartRap Core Build April 16, 2015 05:20PM |
Re: My SmartRap Core Build April 16, 2015 06:32PM |
Re: My SmartRap Core Build April 19, 2015 08:22PM |
Re: My SmartRap Core Build April 20, 2015 11:41AM |
I didn't even realize I needed to do that. Upon further inspection this morning I noticed the holes. I will tap them tonight and see if that helps at all. My bigger problem is attaching the belts to the x carriage. I have 3/4 pushed in but the last one got gummed up on the print, so I'm gonna have to try to remove some material somehow to fit the belt in there.Quote
djinn5150
From the pic it doesn't appear you have the x rod lock screws installed( at least that I can see) That will have an effect on the tension of the rods as well. I found they have to be installed on at least one side of the "y slide" to keep the rods in position.
I love Fusion 360. Of course the free part is fantastic and the modeling is great! But for me, the CAM functionality and simulation is the biggest factor. With my CNC mill, having one piece of software for everything is AWESOME! Simplifies the entire process.Quote
djinn5150
Very glad to see someone else playing around in Fusion 360, the more I use it the more I am loving it. I was kicking around the idea of using extrusion for at least the x carriage myself. It will definately be a more robust design that is for sure.
Why do you think the belts wouldn't work? I was thinking they'd be easy because you could just add spacers/washers to the Idler/Bolt combo to get the heights right.Quote
madmike8
So, do you think the belts will work with the way you have your makerslide configured?
I didn't notice mine off center, but the bearing was too tight in mine though, and the belt wouldn't fit through between the plastic and the bearing. I ended up drilling out the slot quite a bit to get it all to fit.Quote
rcjoseb
I printed out the top Z plate that holds the 608zz bearing in place and noticed that the slot for the bearing is not centered on the piece. Anyone else notice this? Any reason why it would be off centered?
