My SmartRap Core Build V1.0
Posted by jgvonk1984
May 03, 2015 09:03AM
I started making a SmartRap Core. I have a question about, the Z GT-2 or M8 threaded rod? I have tested the GT-2 and it can be used for the Z. But what is more accurate? GT-2 or threadedrod M8?
Buildsize Width 200 Heigt 300 Depth 200
Wood 12mm
XYZ Smooth Rods 8mm
Z threaded rod M8
Motors Nema 17
Woodframe 12mm Multiplex
Bottom 389x322
Left 322x440
Right 322x440
Back 365x440
Smooth Rods 8mm
Z 2x410
Y 2x265
X 2x255
This is the BOM for my build
My Prusa i3 is busy printing all partsspinning smiley sticking its tongue out
I will keep a record here of my build
Edited 2 time(s). Last edit at 05/05/2015 03:32AM by jgvonk1984.
Re: My SmartRap Core Build V1.0
May 03, 2015 09:53AM
Im going with the threaded rod. I feel the belts could get wobbly and lose tension after a while i would rather have a set and forget type of system
May 03, 2015 11:00AM
Personally I can't speak for the the belts as I have yet to use them, but they shouldnt loose tension at any rate faster then the x/y axis, resolution on a 20t pulley should be as good as your x/y, it is definately faster then a leadscrew But I do prefer the leadscrew, its what I know, its familiar, it doesn't fall down under power failure, or if I disable steppers during a pause. If your coming from a Prusa you will feel right at home with the Z leadscrew.
The youmagine openjscad threaded z is broken last I heard
[www.youmagine.com]
This is my fix, works well been using it for a while now without touching it
Welcome to the Core Crew
May 03, 2015 06:11PM
Has anyone already made the hotend suspension suitable for E3D V6?
May 04, 2015 02:43AM
There is an updated STL link in one of the threads here for it
May 05, 2015 08:19PM
Is this what you are after? [onedrive.live.com]
See my pre-build questions thread if that doesn't work.
