Direct Extrusion April 16, 2016 05:20PM |
Re: Direct Extrusion April 17, 2016 03:58PM |
Re: Direct Extrusion April 18, 2016 06:01AM |
Re: Direct Extrusion April 18, 2016 08:17AM |
Re: Direct Extrusion April 19, 2016 02:15PM |
Re: Direct Extrusion April 19, 2016 03:51PM |
Re: Direct Extrusion April 20, 2016 01:30AM |
Re: Direct Extrusion May 06, 2016 03:23PM |
Re: Direct Extrusion May 06, 2016 03:38PM |
Re: Direct Extrusion May 06, 2016 04:21PM |
Re: Direct Extrusion May 09, 2016 08:54AM |
Re: Direct Extrusion May 12, 2016 02:41AM |
Re: Direct Extrusion May 12, 2016 05:11AM |
ixlix
I found a simpler solution, get rid of the pressfit connector on the top of your extruder (cold end) body and use a 4mm nut on the ptfe tube. Example of this would be the airtripper. The pressfits wear out, and have too much slop/movement in them. Anchoring the ptfe tube is the key to consistent extrusion and therefore reduing blobs and zits. Ive noticed my retraction amount is smaller and print quality has increased dramatically since ive down it.
Re: Direct Extrusion May 12, 2016 07:44AM |
Re: Direct Extrusion May 12, 2016 08:35AM |
Re: Direct Extrusion May 12, 2016 08:58AM |
Re: Direct Extrusion May 12, 2016 10:39PM |
Re: Direct Extrusion May 13, 2016 03:48AM |
Re: Direct Extrusion May 13, 2016 07:15AM |
Re: Direct Extrusion May 13, 2016 09:56AM |
Re: Direct Extrusion May 13, 2016 10:01AM |
Re: Direct Extrusion May 15, 2016 04:39PM |
