Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 02:18PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 03:18PM |
Aller Anfang war schwer - Wolfstrap | Reprap-fab.org |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 03:27PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 03:40PM |
Admin Registered: 16 years ago Posts: 13,890 |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 03:54PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 04:47PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor January 31, 2011 04:48PM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 01, 2011 05:18PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 01, 2011 05:27PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 01, 2011 05:41PM |
# Creates a C code lookup table for doing ADC to temperature conversion # on a microcontroller # based on: [hydraraptor.blogspot.com] """Thermistor Value Lookup Table Generator Generates lookup to temperature values for use in a microcontroller in C format based on: [hydraraptor.blogspot.com] The main use is for Arduino programs that read data from the circuit board described here: [make.rrrf.org] Usage: python createTemperatureLookup.py [options] Options: -h, --help show this help --r0=... thermistor rating where # is the ohm rating of the thermistor at t0 (eg: 10K = 10000) --t0=... thermistor temp rating where # is the temperature in Celsuis to get r0 (from your datasheet) --beta=... thermistor beta rating. see [reprap.org] --r1=... R1 rating where # is the ohm rating of R1 (eg: 10K = 10000) --r2=... R2 rating where # is the ohm rating of R2 (eg: 10K = 10000) --num-temps=... the number of temperature points to calculate (default: 20) --max-adc=... the max ADC reading to use. if you use R1, it limits the top value for the thermistor circuit, and thus the possible range of ADC values """
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 03:09PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 03:34PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 03:46PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 03:59PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 04:18PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 02, 2011 07:36PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 03, 2011 06:03PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 03, 2011 07:02PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 04, 2011 11:50AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 04, 2011 12:34PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 04, 2011 12:54PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 10, 2011 09:31AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 10, 2011 10:14AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 11, 2011 03:27AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 11, 2011 05:15AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 11, 2011 05:17AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 11, 2011 07:54AM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 12, 2011 12:21PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 18, 2011 03:30PM |
Re: Thermistortabelle für B57550G1103F005 Thermistor February 18, 2011 05:40PM |
