aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 10, 2014 04:50PM |
dove sbaglio? come posso abbassare il tutto appena do stampa? o meglio quali valori va a leggere?Quote
//// MOVEMENT SETTINGS
#define NUM_AXIS 4 // The axis order in all axis related arrays is X, Y, Z, E
#define HOMING_FEEDRATE {50*60, 50*60, 120, 0} //50*60, 50*60, 4*60, 0 set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,8000,1428 } // default step per unit 78.7402,78.7402,200.0*8/3,760*1.1 // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {2000,2000,40,4000} //9000,9000,100,5000 // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for retracts
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
// #define EXTRUDER_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
// #define EXTRUDER_OFFSET_Y {0.0, 5.00} // (in mm) for each extruder, offset of the hotend on the Y axis
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: aiuto mi stampa fuori tavola e perdo passi Z come si abbassa la velocità in lavoro? March 10, 2014 06:23PM |
Re: aiuto mi stampa fuori tavola e perdo passi Z come si abbassa la velocità in lavoro? March 10, 2014 06:35PM |
questo problema risolto abbassando cosiQuote
lion_heart78
Abbassa l'accelerazione max dell'asse z a 1000 (e magari anche quella di default).
Poi per il piano capisci bene cosa hai impostato. Se la posizione di standby, se il centro piano, se la posizione di home (traslata).
Per semplicità utilizza come unico riferimento la home sfruttando gli endstops e setta banalmente la dimensione del piano a partire da quello.
Cosa ti dà di più aver il riferimento al centro del piano?
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 02:00AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 03:53AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 05:01AM |
// Travel limits after homing
#define X_MAX_POS 210
#define Y_MAX_POS 210
#define Z_MAX_POS 110
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 05:19AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 05:44AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 06:00AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 07:27AM |
non fare 200 modifiche tutte insieme:Quote
#define X_MAX_POS 217
#define X_MIN_POS 17
#define Y_MAX_POS 262
#define Y_MIN_POS 62
#define Z_MAX_POS 210
prova a reimpostare come da default sia slicer che repetier, fai la modifica solo sul firmware e prova.Quote
per farlo tornare in repetier l ho settato y-62/200 x-17/200
Su slicer ho provato y min 62 max 200 x min 17 max 200...
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 08:15AM |
Ok provo così dopo unico dubbio e che facendo così limito l 4 strutture a muoversi solo sopra il piano di lavoro ma non posso dare quote di svincolo al di fuori di Quell area... strano che non abbiano svincolato queste 2 coseQuote
bonjolo
C'è scritto trave limit after homing, perciò dovrebbero essere gli spostamenti consentiti dopo aver fatto l'home se li setti come hai scritto, dici al firmware che può spostarsi per esempio di 17mm indietro su X dopo che ha fatto l'home (e sbarbarti l'endstop).
considera l'endstop come punto 0, perciò se è fuori dal piano devi indicargli con min il punto dove inizia il piano e come max il punto dove finisce
dovresti ad occhio settarli così:
se non va prova a modificare slicer.
se non va nemmeno così rimetti default su slicer e prova repetier.
segnati cosa cambia a seconda delle modifiche che fai e fai sempre una prova per volta o non arriveremo da nessuna parte.
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 08:28AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 10:27AM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 01:34PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 02:16PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 02:30PM |
(che dovrebbe rimanere valido fino ad un reset della scheda.Quote
M206 X-17 Y-62
vedrai che l'hotend arriverà 2cm dentro il piano su X e 3cm dentro il piano su Y (per sicurezza fallo con la Z alta e manda in HOME solo X e YQuote
G1 X20 Y30
così facendo verranno caricati gli offset ad ogni accensione della scheda.Quote
M500
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 02:52PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 03:39PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 03:49PM |
Nicola P
Buongiorno
questo problema del centramento mi ha messo dei dubbi e ho fatto un po di verifiche: nel mio caso sembra che ne Slic3r ne Repetier riescano ad agire in nessun modo sul posizionamento del piatto di stampa nel caso che l'estrusore abbia maggior area di movimento del piatto; l'unico modo che ho trovato per modificare il posizionamento del piatto è agire sul Firmware (Marlin) e settare X Min e Y Min ad un valore negativo pari alla distanza tra il nozzle e il piatto di stampa in posizione di Home, come era già stato ipotizzato in precedenza. Tutte le altre modifiche non hanno effetto alcuno nemmeno impostando in Repetier una stampante con area di scarto e settando i valori.
Se qualcuno trova altri riscontri mi farebbe piacere provarli
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 03:50PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 04:19PM |
a me non va ma con quali funzioni ti va cosi?cioè dando ad esempioQuote
MagoKimbra
Nicola P
Buongiorno
Io ho fatto cosi su repetier Host e mi funziona, nel menu impostazione stampante - opzioni piatto di stampa, ho Xmin = 0 Xmax =215 e piatto da sinista 15 (15 è la distanza tra lo zero dell'asse x e l'inizio dell'area stampabile, dove inizia il vetro per capirci), Ymin =0 e Ymax 260 e piatto da davanti 60.
Cosi a me funziona.... lasciando come larghezza e lunghezza dell'area stampabile 200mm.
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 11, 2014 04:48PM |
fr4nc3sco
MagoKimbra
Nicola P
Buongiorno
g1 x0 y0 ti va nell angolo del vetro?
e soprattutto con quale firmware?
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" March 12, 2014 02:32AM |
MagoKimbra
fr4nc3sco
MagoKimbra
Nicola P
Buongiorno
Firmware Marlin. Penso che non va perché dai i comandi a mano, mentre repetier invece ne tiene conto e aggiunge 15 alla x e 60 all y. Penso. Perché cosi quando stampo una cosa al centro la fa al centro del piatto, ma se io gli do G1 x100 y100 va in una posizione a sinistra del centro e molto dietro..
edit: Purtroppo io ho la stampante a lavoro e vado a memoria con i parametri, se hai la stampante e puoi fare la prova, prova a mettere xmin=-15 e piatto da sinistra 15 (cambiali con i valori che tu hai) e prova cosi...
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" April 20, 2014 03:02PM |
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" April 20, 2014 03:46PM |
sono mm be la prima cosa è aumentare i limiti su repetier host che comunque va dietro al limite massimo settato nel firmware quindi se li hai 200 anche impostando a 300 in repetier ti troverai fermo a 200 non so se si è capitoQuote
nanigago
Ciao mi intrometto anche io nella discussione perché ho un problema simile prima di fare cavolate vorrei capire se vado a smanettare i parametri giusti. La mia Prusa I3 quando è in home si posiziona da centro HotEnd a 25 mm dal bordo del piatto di stampa, se la mando in +X o in +Y non raggiunge la massima estensione degli assi ma si ferma al centro del piatto di stampa indicando X = 200 e Y = 200 non si sposta più in là, lo stesso capita per l'asse Z che si sposta solo fino a Z = 100, come per il caso sopra basta andare a modificare i parametri in // Travel limits after homing ?
La seconda domanda che vorrei porre anche se ai più sembrerà banale, ma X = 200, Y = 200, Z = 100, misurati su che base? Cioè che rapporto c'è tra questi 200 indicati da Repetier-Host e i cm reali che posso misurare?
Re: aiuto mi stampa fuori dal piano come setto le sue dimenzioni e centro? " perdo passi Z [risolto]" April 21, 2014 08:57AM |
