Operazioni iniziali Delta April 08, 2016 10:10AM |
16:00:11.361 : No start signal detected - forcing start 16:00:54.468 : Communication timeout - reset send buffer block 16:01:47.196 : Communication timeout - reset send buffer block 16:02:45.259 : Communication timeout - reset send buffer block 16:03:49.609 : Communication timeout - reset send buffer block 16:04:53.492 : Communication timeout - reset send buffer block 16:05:57.389 : Communication timeout - reset send buffer block 16:07:01.256 : Communication timeout - reset send buffer block 16:08:05.153 : Communication timeout - reset send buffer block
Re: Operazioni iniziali Delta April 08, 2016 10:18AM |
Re: Operazioni iniziali Delta April 08, 2016 01:04PM |
18:54:06.266 : OpenGL version:1.4 Mesa 11.0.2 18:54:06.267 : OpenGL extensions:GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_multitexture GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_S3_s3tc GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_ARB_depth_texture GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_pixel_buffer_object GL_ARB_texture_rectangle GL_EXT_pixel_buffer_object GL_EXT_texture_compression_dxt1 GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_gpu_program_parameters GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_ARB_copy_buffer GL_ARB_map_buffer_range GL_ARB_ES2_compatibility GL_ARB_debug_output GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_EXT_provoking_vertex GL_ARB_get_program_binary GL_ARB_robustness GL_ARB_separate_shader_objects GL_ANGLE_texture_compression_dxt3 GL_ANGLE_texture_compression_dxt5 GL_ARB_compressed_texture_pixel_storage GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_texture_storage GL_AMD_shader_trinary_minmax GL_ARB_clear_buffer_object GL_ARB_explicit_uniform_location GL_ARB_invalidate_subdata GL_ARB_program_interface_query GL_ARB_vertex_attrib_binding GL_KHR_debug GL_ARB_multi_bind GL_ARB_get_texture_sub_image GL_KHR_context_flush_control 18:54:06.268 : OpenGL renderer:Mesa DRI Intel(R) 945GM x86/MMX/SSE2 18:54:06.268 : Using fast VBOs for rendering is possible 18:55:21.545 : Printer reset detected - initalizing 18:55:21.555 : start 18:55:21.556 : External Reset 18:55:21.556 : MK_4.2.8_dev 18:55:21.558 : Last Updated: Apr 8 2016 17:29:45 | Author: (none, Kossel mini) 18:55:21.558 : Compiled: Apr 8 2016 18:55:21.558 : Free Memory: 4351 PlannerBufferBytes: 1232 18:55:21.561 : Echo: Hardcoded Default Settings Loaded 18:55:21.565 : Config: Steps per unit: 18:55:21.565 : Config: M92 X80.00 Y80.00 Z80.00 E451.00 18:55:21.569 : Config: Maximum feedrates (mm/s): 18:55:21.574 : Config: M203 X500.00 Y500.00 Z500.00 E45.00 18:55:21.578 : Config: Maximum Acceleration (mm/s2): 18:55:21.582 : Config: M201 X5000 Y5000 Z5000 E1000 18:55:21.586 : Config: Accelerations: P=printing, V=travel and T* R=retract 18:55:21.591 : Config: M204 P3000.00 V3000.00 18:55:21.593 : Config: M204 T0 R10000.00 18:55:21.605 : Config: Advanced variables: S=Min feedrate (mm/s), V=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 18:55:21.614 : Config: M205 S0.00 V0.00 B20000 X20.00 Z20.00 E5.00 18:55:21.614 : Config: Home offset (mm): 18:55:21.618 : Config: M206 X0.00 Y0.00 Z0.00 18:55:21.622 : Config: Delta Geometry adjustment: 18:55:21.631 : Config: M666 A0.000 B0.000 C0.000 I0.000 J0.000 K0.000 U0.000 V0.000 W0.000 R111.00 D235.00 H200.00 18:55:21.631 : Config: Endstop Offsets: 18:55:21.635 : Config: M666 X0.00 Y0.00 Z0.00 18:55:21.640 : Config: Z-Probe Offset: 18:55:21.640 : Config: M666 P X0.00 Y-15.00 Z-11.00 18:55:21.642 : Config: PID settings: 18:55:21.646 : Config: M301 H 18:55:21.647 : Config: Filament settings: Disabled 18:55:21.651 : Info: Power on time: 18:55:21.655 : Info: 0 giorni 0 ore 0 minuti 18:55:21.655 : Info: Filament printed: 18:55:21.659 : Info: 0 Km 0 m 0 cm 0 mm 18:55:21.919 : ---------- FIRMWARE TEST -------------- 18:55:21.921 : --------------- MK -------------------- 18:55:21.925 : Muovi manualmente gli assi X, Y e Z lontano dagli endstop 18:55:21.929 : Vuoi controllare gli ENDSTOP? 18:55:21.929 : Dai il comando Y o N per andare avanti 18:55:21.934 : ***** TEST MOTOR ***** 18:55:21.938 : ATTENZIONE! Controlla che i tre assi siano a piu' di 5 mm dagli endstop! 18:55:21.942 : Dai il comando Y per andare avanti 18:56:04.799 : Communication timeout - reset send buffer block 18:57:09.107 : Communication timeout - reset send buffer block 18:58:13.321 : Communication timeout - reset send buffer block 18:59:17.234 : Communication timeout - reset send buffer block 19:00:21.247 : Communication timeout - reset send buffer block 19:01:25.164 : Communication timeout - reset send buffer block
Re: Operazioni iniziali Delta April 08, 2016 01:41PM |
Re: Operazioni iniziali Delta April 08, 2016 02:36PM |
Re: Operazioni iniziali Delta April 09, 2016 08:43AM |
Re: Operazioni iniziali Delta April 10, 2016 10:34PM |
