Mostlycnc e MKduo
November 23, 2017 04:46AM
Ciao a tutti
ho terminato di costruire la Mostly ma non riesco a farla muovere.
MKDuo 4.3.1
Motori Nema17 asse x 2, asse y 2 asse z 1
I motori degli assi x e y sono in parallelo
Driver DRV8825, tarati a 0,9 V
Repetier host con la stampante settata come CNC Router
Quando mi collego
Il test degli endstop funziona (impostati a NO)
qualunque altro comando (G20, G1 x10 y10) viene ignorato.
!!! quando viene alimentata e collegata i motori girano liberi, a differenza della mia Delta che come do tensione si bloccano
Ho staccato i fili dei motori e li ho collegati a EasyDriver, tutti e tre gli assi funzionano
Allego il mio Overal.h
 * Configuration_Overall.h
 * Here you can define all your custom settings and they will overwrite configurations in the main configuration files.
#define CONFIGURATION_OVERALL
 * Configuration_Basic *
#define SERIAL_PORT 0
#define BAUDRATE 115200
//#define BLUETOOTH
#define BLUETOOTH_PORT 0
#define BLUETOOTH_BAUD 115200
#define STRING_CONFIG_H_AUTHOR "(none, default config)"
#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
#define KILL_METHOD 0
#define NO_TIMEOUTS 1000
//#define ADVANCED_OK
//#define HOST_KEEPALIVE_FEATURE
#define DEFAULT_KEEPALIVE_INTERVAL 2
#define MOTHERBOARD BOARD_RAMPS_13_HFB
#define MECHANISM MECH_CARTESIAN
//#define MECHANISM MECH_COREXY
//#define MECHANISM MECH_COREYX
//#define MECHANISM MECH_COREXZ
//#define MECHANISM MECH_COREZX
//#define MECHANISM MECH_COREYZ
//#define MECHANISM MECH_COREZY
//#define MECHANISM MECH_DELTA
//#define MECHANISM MECH_MORGAN_SCARA
//#define MECHANISM MECH_MAKERARM_SCARA
//#define MECHANISM MECH_MUVE3D
#define POWER_SUPPLY 0
//#define PS_DEFAULT_OFF
#define EXTRUDERS 1
#define DRIVER_EXTRUDERS 1
 * Configuration_Temperature *
//#define TEMPERATURE_UNITS_SUPPORT
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_BED 0
#define TEMP_SENSOR_CHAMBER 0
#define TEMP_SENSOR_COOLER 0
#define TEMP_SENSOR_AD595_OFFSET 0
#define TEMP_SENSOR_AD595_GAIN 1
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 25
//#define SHOW_TEMP_ADC_VALUES
//#define MAX_CONSECUTIVE_LOW_TEMPERATURE_ERROR_ALLOWED 0
//#define MILLISECONDS_PREHEAT_TIME 0
#define TEMP_RESIDENCY_TIME 10  // (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
#define TEMP_BED_RESIDENCY_TIME 0   // (seconds)
#define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
#define TEMP_CHAMBER_RESIDENCY_TIME 0   // (seconds)
#define TEMP_CHAMBER_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_CHAMBER_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
#define TEMP_COOLER_RESIDENCY_TIME 0    // (seconds)
#define TEMP_COOLER_HYSTERESIS 1        // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_COOLER_WINDOW     1        // (degC) Window around target to start the residency timer x degC early.
#define HEATER_0_MAXTEMP 275
#define HEATER_1_MAXTEMP 275
#define HEATER_2_MAXTEMP 275
#define HEATER_3_MAXTEMP 275
#define BED_MAXTEMP 150
#define CHAMBER_MAXTEMP 150
#define COOLER_MAXTEMP 150
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define BED_MINTEMP 5
#define CHAMBER_MINTEMP 5
#define COOLER_MINTEMP 5
#define PREHEAT_1_TEMP_HOTEND 190
#define PREHEAT_1_TEMP_BED 60
#define PREHEAT_1_FAN_SPEED 255
#define PREHEAT_2_TEMP_HOTEND 240
#define PREHEAT_2_TEMP_BED 100
#define PREHEAT_2_FAN_SPEED 255
#define PREHEAT_3_TEMP_HOTEND 230
#define PREHEAT_3_TEMP_BED 60
#define PREHEAT_3_FAN_SPEED 255
#define AUTOTEMP
#define AUTOTEMP_OLDWEIGHT 0.98
//#define HEATERS_PARALLEL
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10 // (degC)
//#define TEMP_STAT_LEDS
#define PIDTEMP
#define BANG_MAX 255
#define PID_MAX BANG_MAX    // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
//#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
//#define PID_DEBUG         // Sends debug data to the serial port.
//#define PID_OPENLOOP 1    // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
//#define SLOW_PWM_HEATERS  // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
#define PID_FUNCTIONAL_RANGE 10
#define K1 0.95
#define PID_dT_FACTOR 1
//#define PID_ADD_EXTRUSION_RATE
#define LPQ_MAX_LEN 50
#define DEFAULT_Kp {40,40,40,40}
#define DEFAULT_Ki {7,7,7,7}
#define DEFAULT_Kd {60,60,60,60}
#define DEFAULT_Kc {100,100,100,100}
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
#define BED_HYSTERESIS        2 // Only disable heating if T>target+BED_HYSTERESIS and enable heating if T>target-BED_HYSTERESIS (works only if BED_LIMIT_SWITCHING is enabled)
#define BED_CHECK_INTERVAL 5000 // ms between checks in bang-bang control
#define MAX_BED_POWER 255
#define DEFAULT_bedKp 10
#define DEFAULT_bedKi 1
#define DEFAULT_bedKd 305
//#define PID_BED_DEBUG // Sends debug data to the serial port.
//#define PIDTEMPCHAMBER
//#define CHAMBER_LIMIT_SWITCHING
#define CHAMBER_HYSTERESIS 2 //only disable heating if T>target+CHAMBER_HYSTERESIS and enable heating if T>target-CHAMBER_HYSTERESIS (works only if CHAMBER_LIMIT_SWITCHING is enabled)
#define CHAMBER_CHECK_INTERVAL 5000 //ms between checks in bang-bang control
#define MAX_CHAMBER_POWER 255
#define DEFAULT_chamberKp 10
#define DEFAULT_chamberKi 1
#define DEFAULT_chamberKd 305
//#define PID_CHAMBER_DEBUG // Sends debug data to the serial port.
//#define PIDTEMPCOOLER
//#define FAST_PWM_COOLER
//#define COOLER_LIMIT_SWITCHING
#define COOLER_HYSTERESIS 2 //only disable heating if TCoreXY HyperCube , MKDuo, HotEnd  0,4 Repetier Host Cura engine
 Mostly CNC   con MKDuo
Re: Mostlycnc e MKduo
November 25, 2017 05:06AM
Nessuno mi può aiutare?
Franco
