Re: stampa in ABS June 07, 2019 08:19AM |
Dado74
...G92 Z0...è corretto?
case 92: // G92
if(!code_seen(axis_codes[E_AXIS]))
st_synchronize();
for(int8_t i=0; i < NUM_AXIS; i++) {
if(code_seen(axis_codes)) {
if(i == E_AXIS) {
current_position = code_value();
plan_set_e_position(current_position[E_AXIS]);
else {
#ifdef SCARA
if (i == X_AXIS || i == Y_AXIS) {
else {
current_position = code_value()+add_homing;
#else
#endif
plan_set_position(current_position[X_AXIS], current_position[Y_AXIS], current_position[Z_AXIS], current_position[E_AXIS]);
break;
inline void gcode_G92() {
bool didXYZ = false,
didE = code_seen('E');
if (!didE) stepper.synchronize();
LOOP_XYZE(i) {
if (code_seen(axis_codes)) {
#if IS_SCARA
current_position = code_value_axis_units((AxisEnum)i);
if (i != E_AXIS) didXYZ = true;
#else
#if ENABLED(WORKSPACE_OFFSETS)
const float p = current_position;
#endif
float v = code_value_axis_units((AxisEnum)i);
current_position = v;
if (i != E_AXIS) {
didXYZ = true;
position_shift += v - p; // Offset the coordinate space
update_software_endstops((AxisEnum)i);
#endif
#endif
if (didXYZ)
SYNC_PLAN_POSITION_KINEMATIC();
else if (didE)
sync_plan_position_e();
report_current_position();
G28 G92 Z-0.2
Re: stampa in ABS June 08, 2019 03:00AM |
Re: stampa in ABS June 09, 2019 05:40AM |
Re: stampa in ABS June 09, 2019 05:49AM |
Re: stampa in ABS June 11, 2019 07:53AM |
Re: stampa in ABS June 12, 2019 04:08AM |
Re: stampa in ABS June 12, 2019 03:47PM |
onekk
...le routine di funzionamento specie sulle schede a 8 bit sono già troppo affollate ...
Re: stampa in ABS October 04, 2019 05:22PM |
Dado74
Alla fine grazie a voi ho risolto il mio problema.
L'ABS titanX è una favola, stampo come se fosse PLA, temperature a parte. per questo ringrazio tantissimo Adryzz.
