problemi LCD e trimmer [Risolto] August 18, 2014 11:12AM |
Re: problemi LCD e trimmer August 20, 2014 06:47PM |
Re: problemi LCD e trimmer August 21, 2014 08:26AM |
Moderator Registered: 13 years ago Posts: 964 |
Re: problemi LCD e trimmer August 21, 2014 09:36AM |
Re: problemi LCD e trimmer August 22, 2014 04:44AM |
//LCD and SD support //#define ULTRA_LCD //general lcd support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) //#define SDSUPPORT // Enable SD Card Support in Hardware Console //#define ULTIMAKERCONTROLLER //as available from the ultimaker online store. //#define ULTIPANEL //the ultipanel as on thingiverse // The RepRapDiscount Smart Controller (white PC// [reprap.org] #define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC
// [reprap.org] //#define G3D_PANEL //automatic expansion #if defined(ULTIMAKERCONTROLLER) || defined(REPRAP_DISCOUNT_SMART_CONTROLLER) || defined(G3D_PANEL) #define ULTIPANEL #define NEWPANEL #endif // Preheat Constants #define PLA_PREHEAT_HOTEND_TEMP 180 #define PLA_PREHEAT_HPB_TEMP 70 #define PLA_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255 #define ABS_PREHEAT_HOTEND_TEMP 240 #define ABS_PREHEAT_HPB_TEMP 100 #define ABS_PREHEAT_FAN_SPEED 255 // Insert Value between 0 and 255 #ifdef ULTIPANEL // #define NEWPANEL //enable this if you have a click-encoder panel #define SDSUPPORT #define ULTRA_LCD #ifdef DOGLCD // Change number of lines to match the DOG graphic display #define LCD_WIDTH 20 #define LCD_HEIGHT 5 #else #define LCD_WIDTH 20 #define LCD_HEIGHT 4 #endif #else //no panel but just lcd #ifdef ULTRA_LCD #ifdef DOGLCD // Change number of lines to match the 128x64 graphics display #define LCD_WIDTH 20 #define LCD_HEIGHT 5 #else #define LCD_WIDTH 16 #define LCD_HEIGHT 2 #endif #endif #endif
Re: problemi LCD e trimmer August 22, 2014 12:55PM |
Re: problemi LCD e trimmer August 22, 2014 01:22PM |
Re: problemi LCD e trimmer August 22, 2014 03:46PM |
Re: problemi LCD e trimmer August 23, 2014 10:13AM |
Admin Registered: 12 years ago Posts: 954 |
| ---- "Let me make my move" ---- |
Re: problemi LCD e trimmer August 25, 2014 11:55AM |
Re: problemi LCD e trimmer August 30, 2014 06:55PM |
Re: problemi LCD e trimmer September 02, 2014 05:03AM |
