3drag collegare lcd 12864 con sd October 24, 2014 10:38AM |
lcd exp1 .. 3drag pin 1 .. nc pin 2 .. PA1 pin 3 .. PA7 pin 4 .. PA5 pin 5 .. PC0 pin 6 .. PC2 pin 7 .. PC4 pin 8 .. PC6 pin 9 .. GND pin 10 .. +5V lcd exp2 .. 3drag pin 1 .. MISO pin 2 .. SCK pin 3 .. PH0 pin 4 .. PA3 pin 5 .. PH1 pin 6 .. MOSI pin 7 .. nc pin 8 .. RST pin 9 .. nc pin 10 .. nc
// The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PCB ) // [reprap.org] ... Controller // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
Re: 3drag collegare lcd 12864 con sd October 25, 2014 05:18AM |
Admin Registered: 11 years ago Posts: 954 |
Re: 3drag collegare lcd 12864 con sd October 25, 2014 07:07AM |
Re: 3drag collegare lcd 12864 con sd November 18, 2014 08:46AM |
Re: 3drag collegare lcd 12864 con sd November 19, 2014 11:45PM |
Re: 3drag collegare lcd 12864 con sd December 01, 2014 02:06PM |
Re: 3drag collegare lcd 12864 con sd December 02, 2014 07:45PM |
