Attivazione\ Dual-pin LaserBeam MKDUE August 01, 2016 05:22AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 01, 2016 05:24AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 01, 2016 05:29AM |
void setup() { // put your setup code here, to run once: pinMode(69,OUTPUT); digitalWrite(69,HIGH); digitalWrite(69,HIGH); digitalWrite(64,HIGH); } void loop() { // put your main code here, to run repeatedly: }
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 03, 2016 07:18AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 05, 2016 08:09AM |
#if ENABLED(LASERBEAM) #define LASER_PWR_PIN 69 #define LASER_TTL_PIN 64 #endifConfiguration Feature
******************************* Laser beam ******************************* ************************************************************************** * * * Support for laser beam * * Check also LASER_PWR_PIN and LASER_TTL_PIN in Configuration_pins.h * * Check also LASER_PWR_PIN and LASER_TTL_PIN in Configuration_pins.h * * * **************************************************************************/ #define LASERBEAM /*
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 08, 2016 11:32AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 08, 2016 03:33PM |
#if ENABLED(LASERBEAM) #define LASER_PWR_PIN ORIG_FAN_PIN #define LASER_TTL_PIN 18 //PIN LCD D16 pinout
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 09, 2016 10:51AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 10, 2016 12:42PM |
sensore di temperatura di bed ed estrusore = 999 (DUMMY TEST) LASERBEAM CONTROL 2 #if ENABLED(LASERBEAM) #define LASER_PWR_PIN 69 #define LASER_TTL_PIN 64 #endif
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 21, 2016 11:13AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 23, 2016 09:02AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 23, 2016 09:09AM |
lamerhouse
ciao Manu ....
allora .. in data stellare (come utente star trek ..manca il punto 2016.4 cosi mi piace di più .. se no kirk si arrabbia )
nel caso qui la formula
[attachment 83006 2016-08-23.jpg]
per quanto riguarda alimentazione ... io (parlo di alligator) comando 2 ventole a 12v sul pwn .. ti sei ricordato di abilitare sul firmware la riga
//#define FAST_PWM_FAN
//#define FAN_SOFT_PWM
#define SOFT_PWM_SCALE 0
ciao
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 24, 2016 08:22AM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 24, 2016 01:29PM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 24, 2016 01:30PM |
lamerhouse
ciao provo a controllare questa osa che hai scovato... alberto mi ha fatto abilitare quello sull'alligator se no ..se non ricordo male non alimentava le ventole...
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 24, 2016 01:56PM |
// Uncomment the following if your laser firing pin (not the PWM pin) for two pin control requires a HIGH signal to fire rather than a low (eg Red Sail M300 RS 3040) // #define HIGH_TO_FIRE
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 25, 2016 12:39PM |
Re: Attivazione\ Dual-pin LaserBeam MKDUE August 29, 2016 02:09AM |
