MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 07:16AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 08:04AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 10:09AM |
Arduino:1.8.3 (Linux), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
In file included from /usr/share/arduino-1.8.3/hardware/arduino/avr/cores/arduino/Arduino.h:28:0,
from sketch/src/commands/../../base.h:26,
from sketch/src/commands/commands.cpp:29:
sketch/src/commands/../gcode/temperature/m191.h: In function 'void gcode_M191()':
sketch/src/commands/../gcode/temperature/m191.h:40:20: error: 'MSG_CHAMBER_HEATING' was not declared in this scope
LCD_MESSAGEPGM(MSG_CHAMBER_HEATING);
sketch/src/commands/../gcode/temperature/m191.h:40:5: note: in expansion of macro 'LCD_MESSAGEPGM'
In file included from sketch/src/commands/../gcode/gcode.h:206:0,
from sketch/src/commands/commands.cpp:30:
sketch/src/commands/../gcode/temperature/m191.h:44:13: error: 'class Printer' has no member named 'wait_chamber'
printer.wait_chamber(no_wait_for_cooling);
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560."
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 10:30AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 10:32AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 12:24PM |
exit status 1
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 12:56PM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 08, 2017 01:34PM |
iosonopersia
... in qualche cartella temporanea di Arduino IDE sul tuo pc è rimasta una copia cache del codice precedente. Assicurati di dare una bella pulita, magari con BleachBit.
iosonopersia
Per quanto riguarda il G28 ed il G29, ora li trovi nei file src/gcode/calibrate/g28.h, src/gcode/calibrate/g29_abl.h e src/gcode/calibrate/g29_mbl.h, ma immagino che ci sia sicuramente un modo migliore di farlo, qui il Mago può aiutarti di più.
iosonopersia
se qualcuno si sente pronto per avventurarsi tra le righe di codice è sicuramente il benvenuto. Tra l'altro negli ultimi mesi è diventato molto più semplice da analizzare per via delle riorganizzazioni del codice a cui accennavo in un precedente commento.
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 09, 2017 03:57AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 12, 2017 03:31AM |
Fabius72
L'ho installato, ma in cima alla lista degli "elementi" ripulibili, non trovo nè Arduino IDE, nè AVR, quindi quella cartella dove la posso trovare in BleachBit?
Probabilmente l'IDE non lo trova perchè l'ho piazzato io nella cartella /usr/share/ e ho poi creato il lanciatore.
Fabius72
[...] l'editor di testo è inaccettabile, per cui mi piacerebbe sapere quali strumenti adoperi tu/voi per scrivere/correggere codice o in generale quali trucchetti adoperate per avere una chiara panoramica, ad esempio o come trovare al volo le funzioni che vengono prese in causa da una data circostanza.
git clone "https://github.com/MKFirmware/MK4duo"). Esistono poi comandi per sostituire una certa stringa con un'altra in tutti i file del firmware in un colpo solo... Google è tuo amico.
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 12, 2017 12:31PM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 14, 2017 06:25PM |
sudo add-apt-repository ppa:notepadqq-team/notepadqq
sudo apt-get update
sudo apt-get install notepadqq
sudo apt-get install geany
sudo apt-get install geany-plugins
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 15, 2017 02:22AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 15, 2017 02:48AM |
Re: MK4DUO 4.3.27 dev: problema compilazione con Hot Chamber September 17, 2017 06:21PM |
sudo add-apt-repository ppa:geany-dev/ppa sudo apt-get update
