MarlinKimbra: Zprobe impatta sul piano al termine dell'auto bed leveling June 03, 2015 07:31PM |
void retract_z_probe() { feedrate = homing_feedrate[X_AXIS]; / destination[Z_AXIS] = 50; / prepare_move_raw();
Re: MarlinKimbra: Zprobe impatta sul piano al termine dell'auto bed leveling June 04, 2015 03:16AM |
#define Z_PROBE_RETRACT_START_LOCATION {0, 0, 30, 0} // X, Y, Z, E start location for z-probe retract sequence #define Z_PROBE_RETRACT_END_LOCATION {0, 0, 30, 0} // X, Y, Z, E end location for z-probe retract sequence
Re: MarlinKimbra: Zprobe impatta sul piano al termine dell'auto bed leveling June 04, 2015 03:03PM |
//Amount to lift head after probing a point #define AUTOCAL_PROBELIFT 3 // mm // Precision for G30 delta autocalibration function #define AUTOCALIBRATION_PRECISION 0.1 // mm #define PROBING_FEEDRATE 1000 // Speed in mm/min for individual probe Use: G30 A F600 #define Z_PROBE_OFFSET {0,15,-3.6,0} // X, Y, Z, E distance between hotend nozzle and deployed bed leveling probe. X & Y must are integer... #define Z_PROBE_DEPLOY_START_LOCATION {20,95,30,0} // X, Y, Z, E start location for z-probe deployment sequence #define Z_PROBE_DEPLOY_END_LOCATION {-15,95,30,0} // X, Y, Z, E end location for z-probe deployment sequence #define Z_PROBE_RETRACT_START_LOCATION {-59,68,30,0} // X, Y, Z, E start location for z-probe retract sequence #define Z_PROBE_RETRACT_END_LOCATION {-59,68,5,0} // X, Y, Z, E end location for z-probe retract sequence #define Z_RAISE_BETWEEN_PROBINGS 2 // How much the extruder will be raised when travelling from between next probing points #define AUTOLEVEL_GRID 22 // Distance between autolevel Z probing points, should be less than print surface radius/3.
Re: MarlinKimbra: Zprobe impatta sul piano al termine dell'auto bed leveling June 04, 2015 03:59PM |
Re: MarlinKimbra: Zprobe impatta sul piano al termine dell'auto bed leveling June 04, 2015 04:07PM |
