Tempo Stimato di Stampa 0:00:000 October 02, 2015 10:11AM |
; Default R2 start code ;Basic settings: Layer height: {layer_height} Walls: {wall_thickness} Fill: {fill_density} Print time: {print_time} Filament used: {filament_amount}m {filament_weight}g ;Filament cost: {filament_cost} ;M190 S{print_bed_temperature} ;Uncomment to add your own bed temperature line ;M109 S{print_temperature} ;Uncomment to add your own temperature line M80 G21 ;metric values M82 ;set extruder to absolute mode M107 ;start with the fan off G90 ;absolute positioning G28 ;move to min endstops G1 Z15 F{Z_TRAVEL_SPEED} G90 ; Absolute positioning M82 ; Extruder in absolute mode ; Activate all used extruder {IF_EXT0}M104 T0 S{TEMP0} G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0} G1 F200 E3 ;extrude 3mm of feed stock G92 E0 ;zero the extruded length again G1 F{travel_speed} ;Put printing message on LCD screen M117 R2 in stampa
Re: Tempo Stimato di Stampa 0:00:000 October 02, 2015 11:03AM |
Re: Tempo Stimato di Stampa 0:00:000 October 12, 2015 08:59AM |
Re: Tempo Stimato di Stampa 0:00:000 October 12, 2015 11:17AM |
Re: Tempo Stimato di Stampa 0:00:000 March 21, 2016 09:50AM |
