Problema con UBL e laser su CORE XY MK4.3.6 August 24, 2018 08:59AM |
C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\core\mechanics\core_mechanics.cpp: In static member function 'static void Core_Mechanics::plan_arc(const float (&)[4], const float (&)[2], uint8_t)': C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\core\mechanics\core_mechanics.cpp:709:20: error: 'class Bedlevel' has no member named 'apply_leveling' bedlevel.apply_leveling(pos); ^ C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\core\mechanics\core_mechanics.cpp:720:18: error: 'class Bedlevel' has no member named 'apply_leveling' bedlevel.apply_leveling(pos); ^
In file included from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\../../MK4duo.h:132:0, from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd.cpp:23: C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\../../src/core/stepper/stepper.h: In function 'void lcd_implementation_status_screen()': C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\../../src/core/stepper/stepper.h:68:21: error: 'block_t* Stepper::current_block' is private static block_t* current_block; // A pointer to the block currently being traced ^ In file included from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd_impl_DOGM.h:289:0, from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd.cpp:53: C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\dogm/status_screen_DOGM.h:192:19: error: within this context if (stepper.current_block->laser_status == LASER_ON) { ^ In file included from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\../../MK4duo.h:132:0, from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd.cpp:23: C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\../../src/core/stepper/stepper.h:68:21: error: 'block_t* Stepper::current_block' is private static block_t* current_block; // A pointer to the block currently being traced ^ In file included from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd_impl_DOGM.h:289:0, from C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\ultralcd.cpp:53: C:\Users\Nicola\AppData\Local\Temp\arduino_build_292608\sketch\src\lcd\dogm/status_screen_DOGM.h:194:39: error: within this context lcd_put_u8str(itostr3(stepper.current_block->laser_intensity)); ^
Re: Problema con UBL e laser su CORE XY MK4.3.6 August 29, 2018 03:33AM |
Re: Problema con UBL e laser su CORE XY MK4.3.6 September 03, 2018 06:06AM |
Re: Problema con UBL e laser su CORE XY MK4.3.6 September 14, 2018 03:25AM |
private: /** Private Parameters */ Da modificare in //private: /** Private Parameters */
Re: Problema con UBL e laser su CORE XY MK4.3.6 October 03, 2018 01:27PM |
Re: Problema con UBL e laser su CORE XY MK4.3.6 October 04, 2018 03:20AM |
whitedavil
Dopo vari aggiornamenti del Mago, il problema persiste con il comando LASER.
In realtà è causato in quanto , probabilmente per errore, alcune funzioni in STEPPER.H sono state dichiarate private.
Rendendole pubbliche, tutto comipla correttamente.
In particolare la voce da modificare è la seguente alla riga 66:
Devo però ancora verificare se realmente poi tutto funziona.
Re: Problema con UBL e laser su CORE XY MK4.3.6 October 04, 2018 12:55PM |
Re: Problema con UBL e laser su CORE XY MK4.3.6 November 05, 2018 04:51AM |
