Re: MarlinKimbra + Nextion HMI TFT
March 11, 2017 05:33PM
Hi to you all,
sorry that I have to write in English. I'm from Germany and unfortunately I don't speak Italian :-(
I'm building a Delta 3D printer and I have to choose the electronics. Because I have a Nextion TFT here I'm asking myself if I can make it work with one of the usual controller boards?
Best would be RADDS, because there's also a big German community, but I'm also looking at MKS SBASE or Duet. It only has to be 32bit.
Could you give me some advice?
Thanks a lot and best regards
Mischa
March 11, 2017 05:50PM
Hi manwald and welcome,
I have coupled RADDS + Nextion on my printer and works great!!
It's a cartesian but I think on delta is the same.
Maybe delta users can help you better.
ITALIANS DO IT BETTER..!!
Claudio M.
Mendelmax 1.5 mod. > Bulldog Lite extruder - Winomo Hotend - Ramps 1.4 - fw MK4duo 4.3.8
Goblin3D2 > Bulldog XL extruders - Winomo Hotends - Radds 1.5 - Nextion 7" Diamond LCD - Octoprint - DRV8825 - fw MK4duo 4.4.0
3Dragon > CoreXY - Bulldog XL extruder -Winomo hotend - Radds 1.5 - Nextion 7" Diamond LCD - DHT22 sensor - Octoprint - TMC2100+DRV8825 - fw MK4duo 4.4.0
March 11, 2017 05:59PM
Hi Claudio,
that sounds great! Thanks for your reply.
So, I need a RADDS board, an Arduino Due and the MK4Duo-firmware?
Is it only in Italian? And is there any English (or better German) translation or instructions, especially how to use it with a Delta?
Mille gracie :-)
March 11, 2017 06:28PM
yes,
RADDS + Arduino Due + MK4duo (very good choice!)
MK4duo is multilanguage but if you connect a Nextion display, commands and menu are only in english (for now!)
Claudio M.
March 12, 2017 03:01PM
That sounds really good!
Is there any chance to translate the commands and menu to German? It doesn't really matter, but it would be more comfortable :-)
So, I heard a lot about Repetier-firmware, some are using Marlin - MK4Duo is better, you say?
Is it hard to configure this firmware to work with my self-built Delta printer?
March 12, 2017 03:29PM
manwald on [www.marlinkimbra.it] you can find the firmware configurator online.. Go on MK4duo 4.3.1 stable and try it...
My Blog - My Thingiverse
March 12, 2017 03:33PM
Thank you very much - this looks really promising!!!
Edited 1 time(s). Last edit at 03/12/2017 03:33PM by manwald.
March 23, 2017 06:40AM
Ciao a tutti
il nextion funziona bene se montato con la ramps? Sempre MKduo..
Grazie
COREXY 300x300x320 - Arduino due/RADDS 1.5 con MK4Duo 4.3.8
March 31, 2017 05:45AM
Ciao intanto vi faccio i più vivi complimenti al mago al grafico e a tutti quelli che hanno partecipato a realizzare l'interfaccia del nextion è fenomenale lo sto usando insieme alla alligator v2 ed è davvero di un bell'impatto....
volevo chiedervi solo una cosa, nel menù dei movimenti funziona tutto bene quindi per caricare il filamento (ho il bowden e hotend IEC) sto facendo estrudi 10cm alla volta e ok, ma le velocità sono un pochino troppo alte e ogni tanto mi scatta l'estrusore.....ho visto che c'è un load unload filament ma non funziona ....sarebbe comodissimo visto che si puo' selezionare la velocità di load e unload del ilamento....cosa devo aggiungere o fare per far funzionare questa comodità da display ??? Grazie mille e ancora complimenti
Edited 1 time(s). Last edit at 03/31/2017 05:51AM by RikyRap.
Il mio blog su Stampa 3D, Arduino e Multicotteri
[riccardoquirici.wordpress.com]
CoreXY, Alligator v2, Igus e Skf, flusso canalizzatore hot end IeC, MKDUO, Nextion display 4.3, in evoluzione...
[youtu.be]
Prusa i3, Ramps 1.4, Greg wade con filo 3mm e ugello 0.5, Slic3r, Cura, Repetier Host, Sprinter Firmware.
[www.youtube.com]
April 03, 2017 03:54PM
Mi pare di non aver visto niente in proposito, quindi chiedo, si puo' montare il nextion su una scheda mks gen 1.4 8 bit ? e si si dove si collega ?
Ho gia' installato l'ultimo dev della marlinduo
Grazie
April 25, 2017 07:11PM
......domani c'è il gran collaudo!!
Se tutto va bene, preparate birre e panini e non prendete impegni per il weekend....!! spinning smiley sticking its tongue out
Claudio M.
April 27, 2017 12:25PM
Mr.Goblin
April 27, 2017 01:11PM
Salve a tutti, tossici del Nextion.....
essendo il collaudo andato a buon fine sono qui a proporvi il display che non c'era!! (oggi me la voglio tirare!)
Quindi mano a birre e panini e gustatevi il solito video.....smileys with beer
[youtu.be]
Se sarà di vostro interesse sarò lieto di darvi tutte le informazioni in proposito....
Ciao ciao.
Claudio M.
April 27, 2017 01:31PM
Che dire... È semplicemente così come dovrebbe essere, veramente un bel lavoro!
April 27, 2017 01:36PM
Una domanda: quel sensore di movimento sopra al display ha un effetto pratico? Mette per caso il display in stand-by se si supera un periodo di tempo in cui l'utente non interagisce? Sarebbe una funzionalità interessante
April 27, 2017 01:42PM
L'intento è quello...
al momento, superato un tempo prestabilito spegne le luci sul piatto e abbassa al 5% la retroilluminazione del display.
Ovviamente, se qualcuno si avvicina alla stampante il tutto si riaccende per poi rispegnersi se non c'è nessuno nei paraggi.
Sto testando uno screensaver e la messa in stand-by (sleep) del display.
Claudio M.
April 27, 2017 03:12PM
Che figata!! Io ho il 4.3 con la tua grafica e già è una bomba ma questo è proprio next level da pro! Complimenti!!! Si potrebbe pensi avere qualche scaling per il 4.3 oppure poca risoluzione fa venire troppo attaccate le finestre ?
Edited 1 time(s). Last edit at 04/27/2017 03:12PM by RikyRap.
[youtu.be]
[www.youtube.com]
April 27, 2017 03:13PM
Ottimo lavoro!!!
April 27, 2017 03:26PM
Grazie a tutti...
RikyRap... mi dispiace ma adattarlo al 4.3" è impossibile!
Claudio M.
Davvero ottimo lavoro!
Ora aspetto che esca la AllyV3, mi prendo un Nextion 7" e mi rifaccio l'elettronica della Prusina! grinning smiley
Grande veramente!
PS: con che scheda gira attualmente?
Prusa i3 R2 + The Shell - Saintsmart Ramps 1.4 - Mega2560 R3 - Driver A4988 - Firmware MarlinKimbra
Mini Kossel - Alligator - Firmware MarlinKimbra4due
April 27, 2017 03:28PM
Mr.Goblin
Grazie a tutti...
Ottimo lavoro!!! si potrebbe avere il file? anche io ho il nextion 7. grazie mille
Con la Radds 1.5
Claudio M.
April 27, 2017 03:40PM
Per il momento preferisco non divulgare il file.
Voglio fare ulteriori ritocchi.....
Comunque vi ricordo che per usufruire di tutte le funzionalità bisogna avere la versione enhanced.
Altrimenti dite addio a metà del software.
Claudio M.
April 27, 2017 04:05PM
heheh è l'unica cosa che non hai scritto in firma grinning smiley
April 28, 2017 06:47AM
et voilà...ora c'è tutto.
Claudio M.
April 28, 2017 07:23AM
RikyRap
Per il / è fantastico ma @RikyRap hai la versione di @Mr.Goblin per il 4.3 confused smiley ma è stata rilasciata?
Si potrebbe avere?
Hictop ALLUMINIO RepRap Prusa i3 3DP11 Radds V1.6 DRV8825
Nozle 0.4 filo 1.75 Nextion display 7" Diamond MK4duo 4.3.2
Ender 3 V2
Nozle 0.4 filo 1.75
Biqu B1
Nozle 0.4 filo 1.75
April 28, 2017 07:26AM
Da mo è nel firmware....
April 28, 2017 07:32AM
MagoKimbra
ma parla del fw o dei pollici ?
April 28, 2017 08:03AM
Del firmware, la versione disegnata da MrGoblins già c'è da un bel pezzo, rispondevo a paolopa..
April 28, 2017 08:41AM
Mr.Goblin
thumbs up
