Wire gauge and a near serious accident April 06, 2015 08:40AM |
Re: Wire gauge and a near serious accident April 13, 2015 11:26AM |
Re: Wire gauge and a near serious accident April 13, 2015 03:08PM |
iamdarkyoshi
I always overbuild stuff. My 6A bed is being run from 8 gauge super flexible ptfe core car audio wire and it is soldered directly on the controller. Obviously such a massive wire gauge is overkill, but is is super bendy and it stays stone cold. Good luck with your wiring and be careful!
Re: Wire gauge and a near serious accident April 13, 2015 05:23PM |
Re: Wire gauge and a near serious accident April 16, 2015 06:54PM |
Re: Wire gauge and a near serious accident April 16, 2015 09:10PM |
Re: Wire gauge and a near serious accident May 12, 2015 03:05AM |
Re: Wire gauge and a near serious accident May 14, 2015 02:17PM |
Re: Wire gauge and a near serious accident May 14, 2015 03:39PM |
itchytweed
Ohm does not like his law being violated.
Heated beds are big current eaters. Mine is 34 amps when running. This requires serious copper - running 10 gauge stranded feeder from the power supply.
Re: Wire gauge and a near serious accident May 19, 2015 10:54AM |
dc42
itchytweed
For that sort of power, IMO a mains powered heated bed is generally a better option. That is what I have on my large delta. Of course, using mains voltage to heat the bed brings an additional set of safety concerns, especially on a machine with a moving bed.
Re: Wire gauge and a near serious accident May 19, 2015 03:09PM |
itchytweed
dc42
itchytweed
Mains voltage on a heated bed? That brings it own huge bag of issues with it. Going from low voltage to high voltage ( > 48 volts ) and the attendant issues of arc flash protection, different wiring practices, etc. Even though the current is higher, I will stick with the 14.2 volts that runs the whole show.
Re: Wire gauge and a near serious accident July 20, 2015 03:44AM |
Re: Wire gauge and a near serious accident July 20, 2015 05:11AM |
sarf2k4
May I know what is your wire gauge, sleeve/insulation type, length and resistance?
Re: Wire gauge and a near serious accident July 21, 2015 08:18AM |
Re: Wire gauge and a near serious accident July 22, 2015 08:02AM |
sarf2k4
I bought a 16awg wire with silicone sleeving rated around 100'c, 5 meters for a pair of them from aliexpress. I didn't cut them to my required minimum length yet so the wire resistance are rated at 0.4ohm at 5 meters.
This wire will be used to connect from the psu to the board. I still haven't measure the current stock wire that I have now on my gtech prusa printer
Re: Wire gauge and a near serious accident July 22, 2015 08:01PM |
Re: Wire gauge and a near serious accident May 03, 2016 12:53PM |
Re: Wire gauge and a near serious accident September 27, 2019 12:02AM |
Re: Wire gauge and a near serious accident September 27, 2019 05:10AM |
Re: Wire gauge and a near serious accident September 27, 2019 06:54AM |
Re: Wire gauge and a near serious accident September 27, 2019 09:44AM |
Re: Wire gauge and a near serious accident September 27, 2019 01:16PM |
That is the strange part because there is no kinks or bends in it but it does have spade lugs to go into the terminal so with the silicone wire I am not going to use them again.Quote
leadinglights
There are good engineering reasons not to use wire that is too thick. Insufficiently flexible wires and the addition of moving mass to the bed are points to bear in mind as well.
The heating that Dark Alchemist mentions is possibly due to high resistance joint in the connector/crimped terminal/soldered joint at the power supply end.
BTW, the 22 AWG (0.327mm²) thin-wall silicone wire that I mentioned above was about twice the price of 14AWG (2.08mm²)
Mike
Re: Wire gauge and a near serious accident September 28, 2019 02:53AM |
Dark Alchemist
Re: Wire gauge and a near serious accident September 28, 2019 04:01AM |
Yep, but they haven't discolored a bit just the 100mm of wire leading up to them. I bet they are getting hot and the heat is leading down the wire though it is strange they have no discoloration anywhere on them. I sized my wire based on the total length of the run and the amperage demanded of it and my figures never said it should get to 70c+. I figured it would be warm to the touch now if I doubled my length I would have needed a higher gauge. As it is the 12 gauge silicon wire should take of it and no more spade lugs but they sure were handy.Quote
MKSA
Dark Alchemist
A poor crimp will lead to a poor contact that will worsen due to the heat cycles. Most failures occur at the contacts, not the wire itself unless grossly undersized.
Re: Wire gauge and a near serious accident September 28, 2019 07:49AM |
Re: Wire gauge and a near serious accident September 28, 2019 01:03PM |
Nope, they were crimped with a proper ratcheting tool with no bends or kinks.in them.Quote
leadinglights
I assume that the spade lugs are crimped on. Crimping is the best way of connecting a wire but it comes with a big BUT. It is only good if it is done right. The metal of the wire and the lug must be deformed sufficiently that there is a large area of contact and, very importantly, the deformation must be plastic: Metals, when bent slightly, will spring back but when deformed past a critical point will deform plastically and not spring back. Crimping with a worn out or otherwise inadequate crimping pliers risks not getting to the plastic deformation and the metal springing back and giving a poor contact.
The genuine manufacturers crimping pliers can be breathtakingly expensive but some cheap ones will do the job but don't take it on faith. Try making a few test crimps and try to pull the wire out of the crimp using a lever if necessary - if it can be pulled out then the pliers are not up to it.
Soldering is genuinely not as good as a sound crimped connection but much much better than a bad crimped connection.
Mike
Re: Wire gauge and a near serious accident October 01, 2019 12:57AM |
Re: Wire gauge and a near serious accident February 04, 2021 07:52PM |
Re: Wire gauge and a near serious accident February 05, 2021 01:48PM |
Re: Wire gauge and a near serious accident February 05, 2021 02:59PM |
