Earthing Aluminium Extrusion?
Posted by WesBrooks
December 14, 2017 03:23AM
Hi All,
I'm looking at earth bonding my machine to save any potential H&S and compliance issues and as an electrical noise control measure.
Aluminium is a bugger for oxidising fast and making poor electrical connections.
What would people recommend? I'm thinking tap, and sand/grind back the anodising around the hole brass screw and star lock washer to bite in a bit?
I'm planning to bond what I can back to a single point including the stepper motor bodies. Thankfully they're static on a core-xy! Y-axis gantry and hot end could be a pain to deal with. I think a bit of braiding shoved in the clamp on the cold end of the hot end will be enough. Better than nothing I guess!
Edit: All earth bonding will be man enough to take enough current to blow the fuse on the outlet of the heaters and stepper PSU.
Edited 3 time(s). Last edit at 12/14/2017 03:25AM by WesBrooks.
VDX
Re: Earthing Aluminium Extrusion?
December 14, 2017 05:25AM
... I'm using a notched(?) washer under a normal washer to cut through the oxide layer ...
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
December 14, 2017 05:36AM
Yeah having imaged searched that's what I meant! :-D
PRZ
January 21, 2018 06:50AM
That ?
Edited 1 time(s). Last edit at 01/21/2018 07:19AM by PRZ.
Pierre
- Safety [reprap.org]
- Embedded help system for Duet and RepRap Firmware [forums.reprap.org]
- Enclosed delta printers Lily [rouzeau.net] and Lily Big [rouzeau.net]
- OpenScad delta printer simulator [github.com]
- 3D printing on my site [www.rouzeau.net]
