WARNING: Simplify3D causing potential fire hazard April 07, 2018 10:37AM |
Re: WARNING: Simplify3D causing potential fire hazard January 01, 2019 02:40PM |
Re: WARNING: Simplify3D causing potential fire hazard January 02, 2019 02:12AM |
Re: WARNING: Simplify3D causing potential fire hazard March 07, 2019 06:05PM |
atmark
Hi
I had a large print going on the other day, which I needed to print overnight. Fortunately I woke up and I was wondering why the printer isn't making any noise. The print had stopped after few hours leaving the still hot extruder on the print. The print itself was hot and badly melted. Several clocks in the house were resetted, so there must have been a short power outage. But it hadn't resetted my Mendel90, which was still running hot. So, I stopped printing when I wasn't nearby and awake.
But, now I had the same issue again and again. I'm printing a solid object which take more than 8 hours to print. Several times the print stopped after 1:40h. Finally I realized that the sd card was full and the gcode was only partially saved. There is a bug in the current Mac Simplify3D (v 4.01), possibly also in Windows/Linux. The software doesn't check the integrity of the exported gcode nor does it check if there's enough space on the sd card. This leads to a incomplete gcode where the end script is missing which is essential for shutting off the heaters and homing the print head.
I'm still using my old Mendel90 with Neil Darlow's firmware, which I haven't updated for a long while. The firmware doesn't check integrity of the gcode either, or at least mine doesn't. I'm not sure if this is feature in more recent firmwares!?
So, be careful when using Simplify3D. I've reported the bug today, hopefully they are addressing it immediately.
