At current count, I have 15 separate conductors running through my cable chain to the toolhead:
2 for the extruder fan (+12V, ground)
2 for the part cooling fan (+12V PCM, ground)
2 for the heater cartridge (+12V PCM, ground)
2 for the hot end thermistor (?)
4 for the extruder motor (?)
3 for the inductive sensor (+5V, ground, signal)
I was thinking that there are 4 separate ground wires, as well as two constant voltage wires (+12V for the extruder fan and +5V for the inductive sensor). Any reason I couldn't use a single ground wire for everything, and maybe replace the 5V inductive sensor with a 6-26V sensor and use the same +12V line for the extruder fan and the sensor? I'd probably leave the heater cartridge with its own ground since it goes to a separate tap on the power supply, but I could end up with:
1 Common ground
1 +12V for extruder fan and sensor
1 for the part cooling fan (+12V PCM)
1 for the inductive sensor (only signal)
for a reduction of 3 conductors.
Does this make any sense? Any pitfalls to watch out for?
