corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 05:14AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 10:29AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 11:21AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 11:26AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 12:00PM |
Admin Registered: 16 years ago Posts: 13,902 |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 01:01PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 02:22PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 22, 2015 02:33PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 05:45AM |
wfcook
I don't see any purchase in the normal CoreXY setup. It seems to be a 1:1 system, only for the pruposes of calculating stepper moves the axes have been rotated 45 degrees.
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 08:21AM |
Wurstnase
wfcook
45° and 1/sqrt(2) ratio. Motors needs less force but higher speed.
Also the forces are good to make the X and Y-axis orthogonal. Isn't this enough?
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 09:59AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 10:49AM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 03:43PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 06:05PM |
realthor
Yes of course I get that, I was actually summing the general consensus on this thread and others. I believe that a well built machine will perform the same with all variations of corexy as I see many successful incarnations of all these variations. It is so simple and easy to understand that I am almost tempting into it even if I kind of sworn to rep-rap mentality, therefore thinking about and waiting/expecting a rodless, linear bearing-less, screw-less utopian corexy.
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 07:00PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 23, 2015 08:05PM |
Re: corexy vs non-intersecting corexy: does it make any difference when used with spectra/kevlar line? July 24, 2015 07:05AM |
