Alternative to Bowden extruder August 17, 2015 07:34AM |
Re: Alternative to Bowden extruder August 19, 2015 07:32AM |
Re: Alternative to Bowden extruder August 19, 2015 08:02AM |
AndrewBCN
You can use a Greg's Wade's Geared Extruder with basically any 3D FDM printer, and there are Bowden versions of the Greg's Wade's too. Note that unless you run a PTFE tube from the nozzle right up to the hobbed bolt, a standard Greg's Wade's Geared Extruder won't work particularly well with flexible filament.
In the case of both Core XY and linear delta printers, you are better off with a Bowden arrangement in any case, so printing flexible filaments with these kinds of printers is not recommended, and most people rarely have a need to print with flexible filaments anyways.
If you really have a need to print various kg of flexible filament, you are advised to use a separate printer with an extruder on the print head (meaning probably a Cartesian design) and an extruder design with a proven history of good quality printing with flexible filaments.
Re: Alternative to Bowden extruder August 19, 2015 02:41PM |
AndrewBCN
Re: Alternative to Bowden extruder August 22, 2015 12:39AM |
Re: Alternative to Bowden extruder September 09, 2015 06:49PM |
Re: Alternative to Bowden extruder September 10, 2015 09:01AM |
Re: Alternative to Bowden extruder October 11, 2015 10:32AM |
