Need help with 1st time Core XY build March 28, 2017 12:05AM |
Re: Need help with 1st time Core XY build March 28, 2017 03:29AM |
Re: Need help with 1st time Core XY build March 28, 2017 08:18AM |
Re: Need help with 1st time Core XY build March 28, 2017 08:28AM |
Re: Need help with 1st time Core XY build March 28, 2017 10:37AM |
Re: Need help with 1st time Core XY build March 28, 2017 10:46AM |
Re: Need help with 1st time Core XY build March 28, 2017 11:43AM |
Re: Need help with 1st time Core XY build March 28, 2017 11:59AM |
scarecrow2k6
Thanks a lot everyone for your replies, what you have pointed out so far, I am already learning a lot. Ok so I have got more questions based on what you guys have pointed out. I should have also mentioned that I am salvaging most of the electronics and some other parts like smooth rods, bearings etc from my old Prusa i3.
@ o_lampe- I did a quick search and it seems like the V-Slot would be the best bet. Btw, why would the 3d models need to be redesigned if I just extend the length of the extrusions?
@ the_digital_dentist- No dual extruders, just single. I was thinking of buying a 500w pc psu to power everything, that should work to power the heater, hotend and the rest of the printer right? What can I do to not fry my board (MKS SBASE 1.3) when using the bed Origamib suggested?
@ Origamib- There are many times I have designed a headphone frame or a quadcopter part but could not print on my 200x200 prusa or delta. I know 400x400 is a bit large, probably 300x300 would do just fine but I was hoping to somewhat future proof it. Btw what did you mean by "how much it will bow over that span"?
Thanks!
Re: Need help with 1st time Core XY build March 28, 2017 10:24PM |
Re: Need help with 1st time Core XY build March 28, 2017 10:44PM |
