Why is CoreXY so special? July 08, 2019 05:43PM |
Re: Why is CoreXY so special? July 08, 2019 05:47PM |
Re: Why is CoreXY so special? July 08, 2019 08:08PM |
Re: Why is CoreXY so special? July 12, 2019 02:08PM |
Re: Why is CoreXY so special? July 12, 2019 02:22PM |
Re: Why is CoreXY so special? July 13, 2019 06:14PM |
the_digital_dentist
You have to align the drive and idler pulley to keep the belt parallel to the guide rails in any belt driven machine.
Re: Why is CoreXY so special? July 13, 2019 10:57PM |
In coreXY, you need to align 4 pairs of idlers/pulleys so the score is the sameQuote
gtj
the_digital_dentist
Yeah but in my Cartesian, there were 4 sets of 2 and only the 2 in each set had to be aligned together... the drive gear and the far end idler.
Re: Why is CoreXY so special? July 14, 2019 12:43PM |
Admin Registered: 11 years ago Posts: 3,096 |
piper3d
gtj
the_digital_dentist
Re: Why is CoreXY so special? July 14, 2019 01:01PM |
Re: Why is CoreXY so special? July 14, 2019 11:41PM |
Re: Why is CoreXY so special? July 15, 2019 09:24AM |
piper3d
Using @the_digital_dentist picture:
[attachment 112036 beltlayout.jpg]
A,B,G,H should be aligned to make square prints rest may not be parallel. Those belt parts each have a pair of idlers/pulleys. (plus F,D,E,C but they have one idler)
Re: Why is CoreXY so special? July 15, 2019 09:29AM |
dlc60
Basically then, it is a Cartesian version of a Delta printer because you don't have to move the X stepper around, which should make it faster, as long as your belts are "stiff" enough to avoid flexing or vibrating too much?
And they look cool.
dlc60
But with their elaborate belt system, aren't they a bit touchy to "tune"?
dlc60
Beyond the weight of the end effector possibly allowing higher speeds, is there any real difference between a Core XY and a "regular" Cartesian in terms of performance?
Re: Why is CoreXY so special? July 15, 2019 09:53AM |
Re: Why is CoreXY so special? July 15, 2019 10:08AM |
Admin Registered: 16 years ago Posts: 13,905 |
Re: Why is CoreXY so special? July 15, 2019 10:10AM |
Re: Why is CoreXY so special? July 15, 2019 04:13PM |
boredom.is.me
There is one benefit. As the print height increases on a printer, so does the mass on the bed. A normal printer has to move that mass while a core xy does not. A normal printer will technically deteriorate as the print gets longer.
Re: Why is CoreXY so special? July 15, 2019 04:19PM |
the_digital_dentist
What does "touchy to tune" mean?
Re: Why is CoreXY so special? July 15, 2019 04:49PM |
Re: Why is CoreXY so special? July 15, 2019 06:18PM |
the_digital_dentist
The belts shouldn't vibrate at all while the mechanism is moving (at least they don't in my printer).
I don't really know if 6mm belts would lead to ringing problems due to stretch, but 9mm belts and pulleys don't cost much more and will certainly stretch less. OTOH, 9 mm pulleys and hardware weigh more so now you have to move more mass that can lead to ringing.
The only way the belts can interfere with each other is if you put them on the same plane. Stacking the belts makes the alignment easier because there are fewer things that need to be aligned to keep the belts parallel to the guide rails.
Re: Why is CoreXY so special? July 16, 2019 07:38AM |
Re: Why is CoreXY so special? July 16, 2019 09:02AM |
the_digital_dentist
In many corexy designs you see around the web, people have made the error of thinking that the belts need to cross in the vertical plane. That's a terrifically bad idea and there's absolutely no reason to do it.
In some builds, stacked pulleys are mounted on posts that are stood up on printed plastic parts and the belt tension tilts the posts inward. That's not a desirable feature and is evidence of poor construction.
I've gathered a bunch of bad designs/builds that you can see here, with comments on the problems.
Re: Why is CoreXY so special? July 16, 2019 09:14AM |
Re: Why is CoreXY so special? July 16, 2019 12:10PM |
Re: Why is CoreXY so special? September 03, 2019 05:54AM |
