Re: Atfer Hbot, go to CoreXY. September 09, 2014 03:44AM |
Re: Atfer Hbot, go to CoreXY. September 10, 2014 02:17PM |
Re: Atfer Hbot, go to CoreXY.ddd September 10, 2014 03:43PM |
Re: Atfer Hbot, go to CoreXY.ddd September 10, 2014 03:53PM |
Re: Atfer Hbot, go to CoreXY.ddd September 10, 2014 04:43PM |
Re: Atfer Hbot, go to CoreXY. September 11, 2014 12:10PM |
Re: Atfer Hbot, go to CoreXY.ddd September 12, 2014 01:12PM |
Re: Atfer Hbot, go to CoreXY.ddd September 12, 2014 01:32PM |
jand
@Doug I did not do a real speed test to figure out the max speed. I normally print at 60 to 80 mm/s. I once did a test at 100 mm/s which gives acceptable results as you can see in this video [youtu.be]
You can see some images of the result of this test here: [imgur.com]
I guess the max speed will be around 120 mm/s in this configuration, that is with a gregs extruder on the carriage.
When you use a bowden system it will probably go faster. This is on my to-do list
Re: Atfer Hbot, go to CoreXY.ddd September 16, 2014 11:45AM |
Re: Atfer Hbot, go to CoreXY.ddd September 16, 2014 12:54PM |
angelo
@dougal
coool :-)
Can I help?
I have also ordered some more Extrusion for my 4 uprights and have gone for 45x45 at 1 mtr long which will allow me to keep everything inside the frame and hence fit covers on it all to act as a heat chamber still trying to decide on electronics tho really do want to go 32 bit if at all possible probably with a RADDS board on either a DUE or maybe even a UDOO (the latter would let me run Linux on it at the same time and then Repetier host on it as well with a monitor attached it could be an awesome machine (If it all works that is)).
Re: Atfer Hbot, go to CoreXY. September 20, 2014 07:23PM |
Re: Atfer Hbot, go to CoreXY. September 20, 2014 10:21PM |
Re: Atfer Hbot, go to CoreXY. September 21, 2014 09:56AM |
Re: Atfer Hbot, go to CoreXY. September 23, 2014 03:16PM |
Re: Atfer Hbot, go to CoreXY. September 24, 2014 10:33AM |
). So I use at 98% Cura slicer, easy, fast, so perfect for me, the only downside, Cura don't have honeyfill filling.|
Re: Atfer Hbot, go to CoreXY. September 25, 2014 03:04AM |
Re: Atfer Hbot, go to CoreXY. September 26, 2014 08:27AM |
Re: Atfer Hbot, go to CoreXY. September 29, 2014 06:42AM |
Re: Atfer Hbot, go to CoreXY. September 29, 2014 10:52AM |
Re: Atfer Hbot, go to CoreXY. September 29, 2014 01:51PM |
zelogik
@marcossf: Nice open case. At first I wanted exactly the same thing, but the corner/profile price increase the cost to much for me... And I have some doubt on the deflection of the frame with fast mouvement.
Re: Atfer Hbot, go to CoreXY. September 30, 2014 02:27AM |
Re: Atfer Hbot, go to CoreXY. September 30, 2014 10:36AM |
Re: Atfer Hbot, go to CoreXY. October 07, 2014 06:16PM |
Re: Atfer Hbot, go to CoreXY. October 07, 2014 08:43PM |
Re: Atfer Hbot, go to CoreXY. October 08, 2014 06:17PM |
Re: Atfer Hbot, go to CoreXY. October 09, 2014 03:04AM |
adambrum
Started my build now following Jands design for printed parts but im using gt2 belts. Most parts are printed, the frame is built and i think all hardware has arrived.
Next big step is to pull my delta apart for the electronics or maybe i should just upgrade to 32bit ?
Re: Atfer Hbot, go to CoreXY. October 09, 2014 03:42AM |
cfeniak
Well, after H-bot.... I went core XY! Should of heeded the warnings
Here is my build:
Core XY on Open Builds
You can see a picture of my original H-Bot in the discussion forum.
Re: Atfer Hbot, go to CoreXY. October 09, 2014 09:13AM |
dougal1957
adambrum
If I were you I would upgrade to 32 bit probably using one of Angelo's RADDS Boards. Mine has just arrived will post photos later.
Doug
Re: Atfer Hbot, go to CoreXY. October 09, 2014 10:49AM |
Re: Atfer Hbot, go to CoreXY. October 09, 2014 10:56AM |
gmh39
Where did you get your RADDS board from? I did a quick search but can't find anything.
